Ls 460 L engine immobilized
Old 05-12-12, 07:53 AM
Sandshrew
Sandshrew's Avatar
Default Ls 460 L engine immobilized
My 2007 Lexus ls460L is completely nonresponsive to anything. The key won't work and it won't lock on unlock from inside the car either. Any help? How would I go about resetting the engine immobilizer?
Old 05-12-12, 08:56 AM
Gs430Boi
Gs430Boi's Avatar
looks like you need a new battery its common
Old 05-12-12, 12:02 PM
JFNash
JFNash's Avatar
Battery Aziz
Old 05-14-12, 02:11 AM
Sandshrew
Sandshrew's Avatar
The car won't lock or unlock from inside drivers side but the red flashing light by the window from the car door works so it's not the car battery and the key battery I replaced same problem.
Old 05-14-12, 04:41 AM
jmcraney
jmcraney's Avatar
Are you able to get inside the car?
Old 05-16-12, 09:40 AM
Xwakeboard
Xwakeboard's Avatar
Originally Posted by JFNash
Battery Aziz
Old 05-16-12, 04:16 PM
Nospinzone
Nospinzone's Avatar
Originally Posted by Sandshrew
The car won't lock or unlock from inside drivers side but the red flashing light by the window from the car door works so it's not the car battery .......
Not necessarily. Those LED's use very, very little power. Door locks, lights, and especially turning over the engine take much more juice. I would check your car battery first.
Moikoi
11-04-15 08:25 PM
BenjiB707
09-22-14 04:43 AM
iTzAndy99
07-23-13 11:56 PM
acenase
SC- 1st Gen (1992-2000)
04-02-07 10:19 PM
Black94RX-7TT
06-07-02 08:40 AM
Quick Reply: Ls 460 L engine immobilized
