Where is this filter located?
I ordered two A/C filters for my LS460 from Park Place Lexus Plano online. When I received them, I found them different from what I have on my car.
They're twice as big as the one installed inside the glovebox and they're white and feel like they're made of cotton. The product description says "hvac, controls, auxiliary heater & ac, cabin air filter LS460, LS460L".
I emailed the company to which they responded that what I ordered was "for the rear ac housing". I don't know what that means. I know the L version has a separate A/C compressor and separate filter in the rear seat whereas the base model has only one compressor and filter, but the description clearly says it's for both the base and L versions.
I attached a pic of what I received. Can any one recognize it and tell me what it is?
Thanks.
Edit:
One more question, how many spark plugs are there in the engine?
Thanks.
Edit:
Thanks.
Edit:
Thanks.
Edit:
https://www.clublexus.com/forums/ls4...460-60k-2.html
Mikey Lulejian - Lake Oconee, GA
Charcoal Filter part number is: 87139-50060
Filter goes inside the glove compartment.
See owner's manual for how to install
Make sure A/C is set to recirculate before installing
Thanks Mikey for the link. I searched before posting and that thread came as the first hit but I couldn't find a sure answer to this question. Can anyone confirm if 8 spark plugs is all what I need?
Also can anyone tell me what is that filter? Is it useful in any way in my SWB LS460?
The problem is when you order the part they don't show the part number. It's just the product description you base your whole decision on. So I emailed the company back raising this issue where the gentleman replied saying "Anytime they use the term auxiliary that means the rear. I’ve been doing this almost 20 years and that still gets me time to time."
That didn't convince me very much. I used their search engine to search for the product and narrowed down the results to the SWB-compatible parts, and the description says it's compatible with the LS460. So where is this "rear ac housing"?
Thanks
Thanks
Go with what the manual says, I bought the spark plugs from my mechanic at his price $14 bucks each (NY Price) original lexus parts. And its 8 plugs you need to buy. I had the same issues like the ones your mentioning with starting a little late and a tad slower at around 65K, after they were installed now is kicking better *** and a little better on MPG!! :-)
