footwell /glove compartment lights
Old 05-25-12, 09:19 AM
marylandlp
marylandlp's Avatar
Default footwell /glove compartment lights
The illumination from the footwell and glove compartment lights are very inadequate for their intended purpose. Are their any plug in replacement led's available?
Old 05-25-12, 10:11 AM
Tee
Tee's Avatar
I removed the orange caps off of the footwell LED's and they are much brighter!
Old 05-25-12, 11:06 AM
InRBigness
InRBigness's Avatar
Put in bright white LED pannels and it is much better, Did my whole car and its amazing the difference it makes.
Old 05-25-12, 12:05 PM
Falbz
Falbz's Avatar
Same here and it gets rid of that ugly yellow color !
Old 05-25-12, 12:29 PM
Tee
Tee's Avatar
Agreed!
Old 05-26-12, 02:39 PM
305Busa
305Busa's Avatar
What are the bulb size on the interior and how many are there?
Old 05-29-12, 09:32 AM
G-SharK
G-SharK's Avatar
Have any of you replace the lights on the door handles to led?
Old 08-31-13, 02:48 PM
Tee
Tee's Avatar
For owners with the Rear Seat Upgrade package with the Cool Box the light inside is also an LED, remove the orange cap like on the foot-well lights and you will be set.
Attached Thumbnails footwell /glove compartment lights-led-cool-box1.jpg   footwell /glove compartment lights-led-cool-box2.jpg
Old 08-31-13, 03:03 PM
Chaos236
Chaos236's Avatar
I did my 911, wow!
Attached Thumbnails footwell /glove compartment lights-shutup.gif   footwell /glove compartment lights-ls4605.gif
Last edited by Chaos236; 02-09-15 at 06:51 PM. Reason: Randy never misses a chance here or on Rennlist
Old 09-02-13, 12:41 PM
RandyV
RandyV's Avatar
Originally Posted by Chaos236
I did my 911, wow!
How does that comment contribute to this discussion?
Noobs.
Old 09-03-13, 06:43 AM
RodT
RodT's Avatar
Originally Posted by randyv
how does that comment contribute to this discussion?
Noobs.
lmao!!!!!!!!!!
Old 09-03-13, 09:24 PM
Chaos236
Chaos236's Avatar
I did LED on my Porsche 997 and Cayenne, it really made the interior look better. If it looks good on one of my cars it usually looks good on the others. ( I trust you can figure that one out) randy
Tee thanks for the tip , I will try it before going completely LED.
I have done my 07 LS my 08 LS is next...
Attached Thumbnails footwell /glove compartment lights-cayenne-001.jpg   footwell /glove compartment lights-997d.jpg
Old 09-04-13, 07:47 AM
PeteinPA
PeteinPA's Avatar
Tee, what did you do about the lights that are located under the rear seat backs? I took a quick look and those appear to have the caps but I was not sure about how to remove the light housing.
Old 09-04-13, 07:55 AM
hkochat
hkochat's Avatar
The foot-well halogen bulbs can be replaced with T-10 LED bulbs in 2013 LS460. Same applied with two trunk lights. The doors courtesy lights in my case came with already LEDs. However I was not able to change the front map lights (main) and rear dome lights to LEDs. The spot lights on both ends of the dome light panels are already LEDs in my case. The main dome lights have the "dynamic lighting" property meaning ramping up and down voltage. When i changed them to LED, the residual power in LEDs keep them ON even after closing the doors. So I had to give-up the modification. has anyone could change the dome lights to LED that has dynamic lighting capability? Just curious.
Old 09-04-13, 08:49 AM
Tee
Tee's Avatar
I used needle nose pliers to pulled the orange caps off or should i say peel them off around the LED bulb. This would also apply to the Cool Box LED as well.
Quick Reply: footwell /glove compartment lights
