suggestions for LS460 L stock to VIP
if you're really serious about this game take a look at the aragosta/youzealand hybrid air suspension that brianlin has -- youzealand disassembles the factory air suspension bag and installs it onto an aragosta coilover. it gives you the ability to use the factory air suspension components and controls and the ability to ride and park super low. it's quite spendy though if you buy new -- somewhere on the order of $6k + your factory components :P
if not, you can try the data systems controller with your factory air, and if that doesn't go low enough, youzealand makes an SS kit for both LS460 and 600h that will lower the car some more (30mm f/r for ls460, 15mm front/30mm rear for 600h).
well, depends on if your car has factory air or not. the air runner setup will be OK if you don't already have factory air.
