Safe ride height for camber?
Old 06-12-12, 09:21 AM
stas2007
stas2007's Avatar
Default Safe ride height for camber?
I am getting some coilovers soon, but noticed a lot of people having camber issues when slammed, I am not looking to be on the ground, just wanna get rid of wheel gap. My goal is to have 1 finger between the tire and wheelwell. Is this doable without issues?
Old 06-12-12, 09:51 AM
lbintab
lbintab's Avatar
what size wheels do you have? To go from 4-5 finger gap to 1 will need about 1.5-2 inch drop. even with that little of a drop you'll have some camber issues but more toe issues.
Old 06-12-12, 10:48 AM
I8ABMR
I8ABMR's Avatar
the stock height is the safest height .LOL In the end the general rule is if you can keep it at an inch or less you should be able to get into the factory specs for the aignment
Old 06-12-12, 11:02 AM
cheez80
cheez80's Avatar
i'm lowered about that much (1 finger gap between tire and fender front, no gap between tire and fender rear, stock size tires and wheels) and i have minimal camber (less than -2*, iirc) -- i was still able to align the car to factory toe specs.
Old 06-12-12, 01:14 PM
datplayaz
datplayaz's Avatar
As long as your toe is in spec, you'll be fine with your drop.
Old 06-12-12, 02:26 PM
rominl
exclusive matchup
rominl's Avatar
as mentioned, again, toe is the key when you lower the car
Old 06-12-12, 06:15 PM
CJITTY
CJITTY's Avatar
I have tons of alignment details with before and after numbers on my Tanabes install thread
Old 06-12-12, 09:00 PM
adamls2
adamls2's Avatar
+1 mine is also lurking around here somewhere. It's all in the toe!!
Old 06-13-12, 07:11 AM
stas2007
stas2007's Avatar
Thanks guys, lets see what happens!
MIca250
04-29-16 09:40 AM
98GS400GUY
Suspension and Brakes
03-24-10 10:05 PM
patrick323
02-16-10 06:58 PM
verals05
IS F (2008-2014)
16
01-03-10 10:58 PM
moo_juice
23
04-02-09 01:42 PM
Quick Reply: Safe ride height for camber?
