Vibration at freeway speeds
Old 08-27-14, 08:22 PM
Nospinzone
Nospinzone's Avatar
The speed range where it happens is a little large, but it sounds like it could also be that one or more of your tires are out of balance. I would have the balance checked. I don't know if they have Hunter Road Force tire balancers there, but that is what you should look for at any tire shop you use.
Nospinzone is offline
Old 08-28-14, 05:32 AM
rakan190
rakan190's Avatar
rotors have been checked and they are good, but I wonder what does it have to do with the vibration , my lexus has no vibration issues when breaking .the vibration starts only on speeds 100-140 . I have been told that only AWD LS has such problem , why AWD cars only? and what would be the exact solution guys! I have just bought the car from a decent guy and although its an old model but it has only 75000km/46000Miles and everything else is perfect .
rakan190 is offline
Old 08-28-14, 06:14 AM
Nospinzone
Nospinzone's Avatar
See post #16.
Old 08-28-14, 09:16 PM
LordBowral
LordBowral's Avatar
Control arms been replaced yet ??
LordBowral is offline
Old 03-30-17, 12:25 PM
1WILLY1
1WILLY1's Avatar
Has anyone else been having these vibration issues or found a cure to them?
My 08 was having very slight vibrations from passenger front (I think) and I thought swapping in new wheels and tires would cure it but I notice its still there ever so slightly , only at times, it comes and goes periodically
1WILLY1 is offline
Old 03-30-17, 02:07 PM
213374U
213374U's Avatar
I have noticed the same (from front passenger corner as well) but it's not bad enough to warrant concern. It's a very minor annoyance when it does occur.
213374U is offline
Old 03-30-17, 05:23 PM
1WILLY1
1WILLY1's Avatar
Yep mine as well
so minor that I can almost convince myself I'm imagining it and it isn't really there
1WILLY1 is offline
Old 03-30-17, 06:26 PM
213374U
213374U's Avatar
Nobody ever notices it but me, I'm just glad to know I'm not crazy.... yet :P
213374U is offline
Old 03-31-17, 12:01 PM
sktn77a
sktn77a's Avatar
Well, considering this is the luxury flagship model of the biggest car maker in the world, I would bug the sh_t out of me!
sktn77a is offline
Old 08-11-18, 07:57 AM
fmast342
fmast342's Avatar
Default 2014 LS 460 vibration issue
I bought it certified pre owned with about 50k miles and experienced the vibration issue at highway speeds and especially when coasting. Took it in and they replaced both left and right front axles and told me the car was now operating as intended. I still feel the vibration at times so if this persists I'm going to keep taking it back.
fmast342 is offline
Old 08-11-18, 08:33 PM
Tec80
Tec80's Avatar
Tell them to check rear driveline angle and use the selective differential front mount shims to correct it. That is what fixed mine!
Tec80 is offline
The following 2 users liked this post by Tec80:
fmast342 (08-12-18), lanceray4 (04-18-22)
Old 10-04-18, 11:35 AM
Tlutrick
Tlutrick's Avatar
So I'm reading through the forum for anything vibration related, as I'm experiencing the same problems as so many with my 2007 LS460 LWB. Been reading some of Tec80's posts on this differential front mount shims. Does that apply to RWD or just AWD? I'm willing to **** on a spark plug if I thought it would help at this point.
Tlutrick is offline
Old 10-04-18, 08:06 PM
213374U
213374U's Avatar
Tec80's fix can apply to either as both have rear differentials .The AWD's of certain years suffer from vibration related to the front driveshafts, which is not possible in the RWD variants.
213374U is offline
Old 10-05-18, 04:27 AM
Dolph1
Dolph1's Avatar
For those that have the vibration how obvious is it? Been trying to figure if I have it on my 13 awd lwb. Does the steering wheel shake like when a tire is out of balance? Or is it barely noticeable where the average joe would be oblivious to it.
Dolph1 is offline
Old 10-05-18, 05:15 PM
213374U
213374U's Avatar
Barely noticeable, but it'll feel like it's coming from the front passenger side of the car if it's the front driveshafts, and usually only when decelerating between 60-45mph.
213374U is offline
Quick Reply: Vibration at freeway speeds
