08 LS460L Navigation Out of Whack
disconnecting a plug in the back of the nav screen will restart / reload the nav. you can also do it by disconnecting / reconnecting your battery i believe. worth a try, though the system is supposed to update itself every now and then.
The GPS antenna is located in the dash, above the display screen, and unlikely to be affected by window tinting on any windows except the front windshield.
The Compass Display screen provides an indication of receipt of the GPS signal. On the Compass Display screen, in the upper left quadrant, there is box that displays "GPS" when the GPS signal is being received from the satellites and it will be blank when no satellite signals are being received. It is normal to not receive the signals when the antenna is in the "RF shade" such as in tunnels.
Mine is nuts aswell !!! It will say I am going north when I am going south , and east when I am going west. The arrow goes backwards and not forwards. My buddy is the head mechanic at Lexus ,and he cant figure it out. I did a firmware update ,and still nothing. Calibration hasnt done anything either.
Here is a link to an explanation that I did a while back that might be helpful: https://www.clublexus.com/forums/6994435-post6.html
Sounds like you may have your display in the "North Up" mode instead of the more conventional "Heading Up" mode.
Oh Brother!!!!! I wish I saw this yesterday I just bought the update for 159$ ,and my buddy is gonna install it for me on Sunday. I sure hope this update works , if not I will try your tutorial
Now that you understand where to look to see if the GPS signal is being received (the compass display mode) you should set your display to that mode and then observe the signal indicator to see if it comes on when you change locations. It is possible to have a localized interfering signal or some sort of shading. If it seems to be very sensitive to shading or position then that might indicate an antenna or antenna connection problem. The signal margin for the GPS is very large and causing a problem by placing something on the dash is vey remote, but it is possible to block the signal by placing something like a folded up sun shade over the antenna.
Had this very same issue! Dealership could not duplicate after multiple visits. So...next time it happened I took out my iphone and video-ed the problem doing 70 mph showing that the passing interstate signs didnt match what was on display. Sent video file to dealership and that finally got their attention.
Net result...Dealership replaced screen and NAV cpu's...about a $6-7K warranty repair. Took several weeks to get parts and Lexus approval. They said there was a low voltage output signal that was causing intermittent issue.
Works great now and made me feel better about purchase of an extended warranty for future issues
