New Dei (aka Viper brands) remote start add on!!
#61
A huge thanks to Damion ( Shibumi1) for the awesome install and diagnostics. It's a really nice mod that I have yet to play with. Here is a short video I made the briefly shows how it works.
If yu guys want something like this den hit up Damion at Next Level in Orlando Fl if you are local. Thanks again Damion!!
P.S. imma get some if those air fresheners ASAP!! Hahaha
#62
Adam..that is sweeeet!! Damion is the man! I'll be down in October.. we need to discuss a package deal on some other electrical mods lol...great video. DEI owes you for the demo
#63
THANKS for the kind words.. i'm just doing my job...we had a lil hiccup but it turns out that its in the newest firmware.. (will have an update tomorrow) spoke to DEI they are on it asap.. Adams a great guy we had alot of fun... 90mph golf cart comin soon...
.off topic.. but if u've gotta have that new car smell.. try this.. its smell like actual leather (a lil goes a long way)
http://www.autoscentsinc.com/xcart/p...&cat=12&page=1
Shivvy (08-25-20)
#67
I have read this entire thread but can not determine if I can do something simple to extend the range of my factory installed remote start and keep my factory remotes. I also have the proximity system to lock/unlock the doors. I would like to avoid using smart start but if that is the only option I would still need to know what to purchase. If possible could you provide specifics with your potential options. Also with any of the potential options including Smart start would they replace my current system or just add the ability to start the vehicle for further away.
#68
as of yet the DBALL wont work on a 2013 RX... but when it does you'll need a DBALL and a smart start (with or without gps) all oem functions will work and the smart start will give the extra range you are lookin for.. keep checking the xpresskit website regularly for updates
http://www.xpresskit.com/rsr.aspx
idatalink has a solution for oem remote start for the 2013 RX (seeing as you have that already it wont work for you) i dont know of a direct link to the smart start with the idatalink..(they usually connect thru an alarm)
#69
#70
#71
Also what did you mean by "(seeing as you have that already it wont work for you)" in your statement relative to the idatalink device.
#72
idatalink indicates I should use ADS-AL CA and would then need long distance transmitters and antenna to perform a long distance remote start without using the smart start technology. Does this sound right?
#73
when programming a DBall for RSR it gives u the option for a range extender remote pkg.. jus choose a remote and add the XL202 module then your good to go..
#74
So I would purchase the DBall and XL202 from Xpresskits web page. Then I would need an antenna and a remote. Or would my existing antenna be used for this application. If I use my existing antenna for the remote start extender will that create an issue with my OEM remote with all the other functions it controls? If I need to buy an antenna which do you recommend. Also which remote to you recommend if all I need is to start the vehicle. Where can I purchase the antenna and remote or just the remote if I use my OEM antenna?
#75
Looks like a pretty cool mod. It would be a great addition to the AZ Summer heat. You would be able to get that AC cranking before you get into the car
