Car says its overheating then goes back to normal??!?!?! WTF
swfla (11-09-22)
#32
I have a 2012 460 Sport (108K miles), and experienced the spiking temp gauge and dash warning while driving at 70mph on the freeway. But as soon as the warning went on, it quickly went off and the temp gauge dropped back to it's normal position. I was quickly able to exit the freeway and turn off the car. When I popped the hood, there was nothing out of the ordinary, no coolant smell, no coolant leaking, no hot smell, hood felt cool (ambient temp was around 60 degrees).
I started the car up, runs and sounds fine, so I continued my drive to the office where I immediately checked the Forum. So consensus is that it's either the thermostat, water pump, or valley plate..I will bring the car to my local indy repair shop hopefully tomorrow. Low coolant light has not turned on either.
#33
I'm having this exact same problem, and while OP didn't deliver on his promise, hopefully someone else with this issue can help.
While it might be the thermo, the needle stays dead steady in the middle 99.9% of the time. Then when I go uphill it spikes up to the max within 2-3 seconds and I get the dash alarm. Then after a few seconds, it drops back down to normal, again within 2-3 seconds, and stays there for a long while (hours). I wouldn't think there is anything the thermo could do to change the temperature that rapidly, so I was suspecting the sensor or the gauge.
Of course I'm taking it into the dealer later today or tomorrow, but just wanted to see if anyone else had the solution. With it happening so infrequently, I'm worried the dealer may not be able to make a diagnosis.
Were you able to find a solution? I have the same issue and have already tried replacing the thermostat. Seemed to have worked for a few weeks but now it’s doing it again.
There seems to be no rhyme or rhythm to it. Just randomly goes up and then comes back down fairly quickly.
Had a pressure test done as well and they found no leaks.
#34
Were you able to find a solution? I have the same issue and have already tried replacing the thermostat. Seemed to have worked for a few weeks but now it’s doing it again. There seems to be no rhyme or rhythm to it. Just randomly goes up and then comes back down fairly quickly.
I assume your coolant is full and stays full?
#35
My issue was low coolant, as I haven't checked it or topped it off in several years. My local indy shop tells me that he tops off LS460 coolant at every oil change --but I've been changing my oil since I bought the car in 2016/17, so my bad. A bigger question is why would the car consume any coolant? The valley plate would see to be a likely culprit but there's no signs or smells of any coolant leaking.
#36
The coolant reservoir cap has a gasket/oring that can go bad. It is supposed to hold pressure. A new cap is inexpensive. Pressure test doesn't test the cap as it's removed to do the test. Once air gets into the system, it can create these symptoms. Just because you can't find a leak doesn't mean there isn't one. Take this opportunity to replace the coolant, it's probably overdue. The tech will purge all air out as well. It'd be great if we could talk through this to find a cause, but sometimes you just need to go hands on with a few inexpensive maintenance/repairs. Have you replaced the temp sensor? What if it's malfunctioning?
HZakiH3 (10-03-23)
#37
swfla (10-02-23)
ebne0018
28
06-14-12 08:44 AM
dantampa
08-25-09 01:38 PM
