DataSystems Air Suspension Controller info thread
#211
Thanks CJITTY. I'll try one of the ebay Vendors since it seems like all the info I need to refresh my memory of how this works in this the thread you help put together. I remember back in the day the main reason most purchased from Prestigious was because they translated their install/user manual to English.
#212
I forgot to mention about these vendors. They are going to resist because the data systems website states which harnesses work for each 460 year. I've always felt this was a marketing thing but we proved the G and H harnesses are interchangeable with the 07 to 12 models for sure. I wish I knew if it would work for the 13s too, but I'd have to try that on one of my local friends 13 LS with air. For example, you won't see the wired advertised for the 10 and up LS models usually. Trying to force people into the higher price set up. But I have seen in person the wired ASC680L working on a 13 F sport flawlessly. So expect some resistance if those vendors are by the book using information from data system website
#214
Just wanted to close the loop on my situation. I did get the ASR861 II for my 2014 LS460 Fsport with the H-087i harness. With this new version wireless between the main console and the control unit is mandatory. Once you get those two devices setup and synchronized, then the other instructions with the ASC680L are applicable. The only difference is when I had the ASC680L on my 2009 LS, you just change your different high settings and it automatically did its thing. With this module, you have to hit the "send" button on the console to make the controller make the changes. If anyone buys these used, make sure you do a factory reboot on both devices and 77 is used for the LS460/L. The Japanese instructions/pictures are for a UCF21 (we are a USF40/45/41/46 or UVF45/46 (LS600h/hl).
Also, the speed senor plug is easy to get to. Its right behind the cup holder vs behind the navigation system on the 2007-12s. I found the English instructions for this version if anyone needs it. I got it from someone back in 2010 but disregarded it because I had the ASC680L.
#219
While I was successful on my 2008 L, I'm not touching my '12 L, because it took several weeks of in wheel well adjustments of the sensors' links to get the car level, again.
#220
Need help
Can you share the English instruction please
thank you
#221
Hello everyone. It's been a while since I chimed in. I recently had to fix a wire on my data systems controller and about to reinstall. I started reading the replies long after this thread was started about the speed sensor harness. I'm thinking the difference between the 2007-09 (G), 2010-12 (H) and 2013-17 (I) harnesses is the speed sensor portion that varies. I have not seen the back of a 07 and 10 nav unit, but I may dig around online to see if my theory proves true. I may just install my speed sensor but i have a 2012 now, not a 2008 so really wondering if my cable will work. Be good to know before I take the screen out..not my favorite task to do but I know how. The main harness behind glove box is a walk in the park now.
#222
Ok..luckily found some pics quickly between 2007-09 and 2010-12 and took pics of my unused speed harness. It looks like that large bottom right connector on each is a match..guess I'll try it
#223
did you ever receive any English translation with your install? I just received mine and I am trying to install it as well and need some help with the set up.
you can email me at gsurujpaul1@gmail.com or call/txt 571-309-1165
thanks
G
#224
thanks
G
thanks
G
Thanks in advance!
#225
thansl for the info.
I have a 2015 and have the module and harness from my 08’.
im hoping both harnesses work for it.
I have some instructions on English but one not. Can I get what you have in English?
also does it give the step by step of taking the car apart to do the install?
if not did you happen to document the steps? Or have any tips?
thanks again!!!!
amack4@me.com
amack4@me.com
