DataSystems Air Suspension Controller info thread
#256
I unpacked the apk and translated all of the texts and created new English buttons. Then i packed into a new apk . We need root to install the app without app signature using SAI . In terms the difference between AWD and RWD is there is a risk of the front drive axles to wear out and breakdown if you drive in a lowered stance . While Rwd does not .
#257
Hi all,
I think this thread is a bit old, so my apologies.
Thanks to CJitty for helping me behind the scenes, giving me the chassis 77 number.
I now have the asr681 ii hooked up to my 2012 LS 600hl and seems to work.
So I got the h1 and h2 settings in: 4-4-3 and 8-8-6.
I might be missing something, but it seems it should go lower? I'm only on the top of the tire on the stock 19s and stock tire size. Maybe I need 22s for the look many have here.
And 2 issues I have:
I cannot get the wireless remote to sync with the device, so I'm using the device manually.
Is it normal to beep so much? Can I disable volume?
I've seen some threads explaining menus, but it seems to be different than the device I have as I cannot get passed the initial settings. I see nothing about setting up 'M1-M5' items or other options for anything other than sdl and spl, which I chose spl
Any help would be greatly appreciated.
Thank you
Thank you
#258
Hi all,
Thank you
Thank you
Also, from what I've read, the AWD models cannot lower quite as far as non-AWD due to the suspension geometry (namely front from what I recall). Hope this helps, and good luck!
#259
I have the ASC680 installed, and while the 681 is similar, I know the menu is different and expanded. There seems to be challenges with the remote feature connectivity, but maybe this thread (even though it's quite old) can help get you started with the basic set up, particularly post# 9 https://www.clublexus.com/forums/ls-...operation.html
I'll mess with it a bit more and see what I can do.
I guess next step is to also pick 22s. I'm picky so this may take a year. Lol
#261
#262
I don't recall a volume screen when I set mine up, but I'll see what I can find out later today when I go for a drive. I have my controller mounted in the glove box, so I'll listen to see how loud and frequent the beeping is. On another note, were you able to get the controller in to extra-down (super low) mode? When starting the car, the controller screen should be red in color. While the controller instructions on the 1st post of this thread are helpful, I found they weren't 100% accurate/clear. I thought there would be a total of 10 memory settings readily accessible, but it is 5 for regular mode and 5 for extra-down. No big deal though, as 5 is more than enough for me. I normally cruise around at 5-front and 4- rear, and if there are speed bumps, dips, etc. I just press the Height High button and that's been able to give me enough clearance.
I was able to go lower than '9' on it and it changed to 'L', and yes it was low. When driving I will probably keep it on 6-6-4.
I still cannot get the wireless module to connect to the wired control box.....but the beeping is driving me nuts. Wife hates it. Lol
#263
Anyone have English install instructions for a ASR681 II w/H-087i PLEASE THANKS my email mdean420@icloud.com
#264
#265
Just wanted to close the loop on my situation. I did get the ASR861 II for my 2014 LS460 Fsport with the H-087i harness. With this new version wireless between the main console and the control unit is mandatory. Once you get those two devices setup and synchronized, then the other instructions with the ASC680L are applicable. The only difference is when I had the ASC680L on my 2009 LS, you just change your different high settings and it automatically did its thing. With this module, you have to hit the "send" button on the console to make the controller make the changes. If anyone buys these used, make sure you do a factory reboot on both devices and 77 is used for the LS460/L. The Japanese instructions/pictures are for a UCF21 (we are a USF40/45/41/46 or UVF45/46 (LS600h/hl).
Also, the speed senor plug is easy to get to. Its right behind the cup holder vs behind the navigation system on the 2007-12s. I found the English instructions for this version if anyone needs it. I got it from someone back in 2010 but disregarded it because I had the ASC680L.
#266
Does anybody know how to disable the beeping?
#267
