DataSystems Air Suspension Controller info thread
Old 09-17-16, 10:50 AM
  #106
LS460LSKYE
LS460LSKYE's Avatar
Originally Posted by Dr. Jekyll
I've used multiple DataSystem controllers and any problems have always been resolved by restarting / setting up the controller again.
How'd you reset it?
Old 09-17-16, 12:36 PM
  #107
Batmobile
Batmobile's Avatar
Originally Posted by LS460LSKYE
I've had this issue off and on for a while but it always seems to fix itself after turning it off and back on... now my car is in semi mode and the driver side is like 3" higher than the passenger side... it literally has a 6" gap between the 22s and the fender on the driver side.. Anyone have a clue what's causing this? I'm honestly about to just get rid of the controller because I'm tired of having issues and now that it's not resetting it's really pissing me off. Luckily I have other cars to drive... I'm thinking disconnect the battery for a bit and see if that resets things.
i had the same issue... However my passenger side is the problem... My
passenger recently is raised a good 6 inches over my driver side... And looks pretty silly when your parked without slamming it down
Old 09-19-16, 05:53 PM
  #108
Dr. Jekyll
Dr. Jekyll's Avatar
How'd you reset it?
Turn the car off, press and hold the menu button and then restart the car.
Old 09-19-16, 05:54 PM
  #109
Dr. Jekyll
Dr. Jekyll's Avatar
Originally Posted by comotiger
Maybe your controller is malfunctioning. Is it Datasystems? Have you called them for advice?
No can do unless you speak fluent Japanese.
Old 09-19-16, 05:55 PM
  #110
Dr. Jekyll
Dr. Jekyll's Avatar
Is this for real? I had no idea there was even 6 inches of travel much less a discrepancy.
Old 09-21-16, 04:35 AM
  #111
Batmobile
Batmobile's Avatar
its pretty ridiculous... have you ever tried height C with height high on? The car can get close to SUV height...
but it I think I fixed mine. I had tried multiple things... which essentially was a combination of turning the car on and off and unplugging and re plugging in the data systems while resetting codes with carista. The car gap is leveled now.. hope this helps someone...
Old 09-21-16, 05:12 PM
  #112
Dr. Jekyll
Dr. Jekyll's Avatar
I only dropped it, never knew of a setting that extended it past "height high"
Old 10-02-16, 04:29 AM
  #113
davano79
davano79's Avatar
I also would like to see the installation instructions as well please.
Old 01-25-17, 07:45 PM
  #114
PeteGS300
PeteGS300's Avatar
Hi All,
I know this thread hasn't been updated in a while but i've got some questions about my Datasystems controller that i've got installed in my LS460.
1 - I was going to take some pictures of my LS the other day so thought i'd lower it down a touch but when i set the height on the controller it lowered one side & seemed to raise the other side - Why does it do this?
2 - I've seen Dr Jekyll's post about resetting the controller but was wondering what height setting (Factory / My settings / Higher than stock) is it best to set the controller to before carrying out the reset on it ?
3 - I take it this is the correct reset method - Turn the car off, press and hold the mode button and then restart the car?
Thank You.
Pete
Old 02-19-17, 06:24 AM
  #115
CJITTY
CJITTY's Avatar
Just an update. I can confirm that the Data Systems main wire harness (H-087G) from the 2007 to 2009 LS model works on the 2010 to 2012 LS model which calls for the (H-087H) harness. The other smaller harness that connects to back of Nav Screen for the speedometer feature that most of us don't use anyway and is not required may or may not work..but the main harness that allows the controller to work is not an issue. So if you are buying or selling a data controller. ..if you have a 07 to 12..the wire harness shouldn't matter whether you have the wired to wireless controller.
The following 2 users liked this post by CJITTY:
213374U (02-19-17), VanCityLS4 (02-19-17)
Old 02-20-17, 08:21 AM
  #116
Oliver Enterprises
Former Sponsor
Oliver Enterprises's Avatar
I, being maybe the latest addition to the ASC family, am PROOF of CJITTY's post above. And the below is evidence. A 2010 model, with a wire harness from a 2007 - 2009.
213374U (02-21-17)
Old 02-20-17, 03:10 PM
  #117
CJITTY
CJITTY's Avatar
Excellent!!! I was hoping you'd post. We had a feeling and it paid off big time for you
Old 02-21-17, 01:19 PM
  #118
213374U
213374U's Avatar
That's awesome news as I've seen more with the 07-09 harness on the used market than the 10-12 harness!
Old 03-21-17, 02:35 PM
  #119
SharksCity
SharksCity's Avatar
Originally Posted by CJITTY
Absolutely it will. I have personally set up the presets in two 2013 LS F Sports using the ASC680L controller with harness for 2013+ models. The harness is not the same as the 2007-2009 or 2010 to 2012 models. I'll have to find the harness number, but I can say with 110% certainty that regular and super low modes work on 2013+ model LS's with the wired controller.
Edit, I looked through my emails The harness for 2013+ LS with ASC680L wired controller is Type 3 (H-087i)
Sorry to Hijacked this Thread
Just Purchased a 13 Ls460 Fsport looking to lower the car. Where can i find this combo to work for my car
ASC680L and wired Control type 3 H-087i
Old 03-21-17, 03:05 PM
  #120
comotiger
comotiger's Avatar
You can visit the company's website. The new unit for your car is $999.
http://www.prestigioussociety.com/?page_id=143
Quick Reply: DataSystems Air Suspension Controller info thread
