Fog lights on with parking lights? LS460 L
Has anyone re-wired fog lights to come on with only parking lights? How did you do it. Do fog lights also stay on now with brights?
Do a google search on Fog light mod clublexus.com and you'll see several posts ..its been done before and I have posted on this topic. Easiest way is HID fogs ans separate switch. It does not touch factory wiring..other geniuses have integrated into factory wiring.
Just a tip..Searching on Google with clublexus.com as part of the search string will work for nearly everything you can think of. I use that daily for my CL research. Fog light mod looks sweeet.
Use Google method..trust me it works better...give it a try.
If you still have no luck, here's your bailout. Acquired in less than 15 secs via google
https://www.clublexus.com/forums/ls4...d-finally.html
