5X114 to 5x120 Adapter for Wheels. Is anyone using them? Where to buy?
Fellas,
I'm located in Miami, Florida and see many wheels available for purchase on Craigslist. I have undeniably fallen in love with the wheel below, and for the price it is selling (see below). I have not had an opportunity to view the rims. However, for the price asked $2500, i find it hard to pass up. THAT BEING SAID ... it is off a Maserati and would require some adapters. Has anyone used them in the past? and currently using them? Is there a recommendation on same? In addition, comments/concerns?
The adapters usually lower the offset, so you need to make sure it will clear your outer fenders. If you get some high quality adapters and torque properly with frequent inspection, you may be ok
UPDATE
I followed up with the seller. He checked and re-checked to see if he could find the offset. The only way i will know is if i try em on. Anyone know where to get some hi-quality adapters?
Yes, I have done google searches.
Thanks,
Thanks,
the offset information is not stamped on the back of the spokes? should say et## or +## something to that effect. Sometimes high end wheel companies are too cool to stamp offsets smh
Found this by searching google for about 15 seconds...
http://prowheeladapters.com/wheel-ad...-adapters.html
I thought this over last night. Im still stuck on if this is a good idea. Say i order the adapters ... then I still have to try the fitment on the car w/ offsets, etc. #whattodowhattodo
Yea, apparently they were too cool to put stamp it on the back of the wheel!
This explains how to measure both backspace and how to calculate your offset, I read an article a long time ago saying the same thing and its pretty accurate...but again, test fit is usually your best bet
if they dont fit you are have get new lips if your lucky there 2 piece instead of 3 and you can get new barrels the plus side to 2 piece is there is no seals to worry about when you change lips. been there done that what a headache. you can get custom ones just do a google search they should pop up, there in vegas but they are great and there price are not bad. you can get some that will be hubcentric to the 460 as well as the wheels which is what u want so there arent any vibrations. im just worried about the adapters pushing the wheels out too far since the smallest you can probably go is about 20mm which is almost an inch. 25.4mm= 1". let us know i know some spots for new lips. 40 holes.
You're looking at 1" adapters. Depending on the car and the offset of those wheels im not sure if it'll work. if for example you went from a wheel off of a ls460 and wanted them on a 7 series then a 1 inch spacer will probably work. But we all don't know how aggressive those wheels are.
Rather than get an adapter and hope the offset is right. Ill just wait for a better deal to come around.
That was me!!! Either way, after taking the advise of many (including club lexus) I will not buy the wheels. Its simpler and less headache to buy something that just fits.
melski415
Wheels, Tires & Brakes Forum
12-20-11 07:59 AM
gsthree
06-24-11 12:31 PM
