New Interior LED Upgrade Mod
Old 12-06-12, 09:02 PM
  #46
SBlexus
SBlexus's Avatar
Pry the back end of each corner at the same time with a couple of thin flat head screwdrivers
Old 12-06-12, 09:11 PM
  #47
DallasLex
DallasLex's Avatar
Thanks. I'll try that.
Old 12-08-12, 06:50 PM
  #48
DallasLex
DallasLex's Avatar
It worked! I'm glad I asked.
Thanks again!
Old 12-08-12, 07:16 PM
  #49
SBlexus
SBlexus's Avatar
Thanks again!
Anytime fellow CL member. Anytime
Old 12-23-12, 07:09 PM
  #50
lexusondubs
dubsonlexus
lexusondubs's Avatar
I would go with the 194-168-5. The ones you pick I think will be too long to fit the factory bracket. The mirrors are simple a 10 mins or less job. Tilt the glass up an pull the glass out,unscrew the 4 screws and pull the 2 pieces apart and the bulb is at the bottom. It's that easy good luck.
got pics ??
Old 01-10-13, 01:29 PM
  #51
adamls2
adamls2's Avatar
I finally got around putting mine in, and I love the results! Here are some pics that I took...
This is the way they are sitting in there...I pushed them in nice and tight at a slight angle to make them fit.
The rear map...
Shine bright like a diamond
It's so damn bright lol, but it's truly awesome. Looks amazing when viewed from outside the car! The only thing that's bugging me now is the mirror puddle lights that don't fit in anymore, hahaha! Big thanks to Tee for this thread!
Old 01-10-13, 02:13 PM
  #52
CJITTY
CJITTY's Avatar
Adam, that is awesome man! Mine are still going strong, but I was able to put mine in square without angle using the actual junction connector as the gap filler to keep them wedged up in there.
Apologies for the on the fly picture edit, but this is what i did to fill the slight gap..using the connector as a wedge then pushed the LED panel perfectly straight in the opening so light shines straight down as much as possible..worked out great
Old 01-10-13, 04:03 PM
  #53
adamls2
adamls2's Avatar
Thanks for the tip man^^^ I'll definitely try that out!
Old 01-10-13, 05:48 PM
  #54
SBlexus
SBlexus's Avatar
Twinkle twinkle, she looks great!!!!
Old 01-10-13, 08:04 PM
  #55
Tee
Tee's Avatar
Looking good Adam, took you long enough lol!
Old 01-10-13, 08:32 PM
  #56
adamls2
adamls2's Avatar
Lmao it's "hella" bright
Haha, I know right? I was overseas for awhile so I had a crap load of parts waiting for me at home Thanks again for your contribution!
Old 05-10-14, 08:07 AM
  #57
Travisbjr
Travisbjr's Avatar
Default dome light replacement
How do you replace the dome light bulbs do I have to remove the screws and pop out the whole covers? 2007 LS
Old 05-10-14, 11:30 AM
  #58
Lexus4me
Lexus4me's Avatar
I think you don't need to, but I always do the hard way remove the whole unit so I learn what's inside.
Old 05-10-14, 11:57 AM
  #59
CJITTY
CJITTY's Avatar
Check FAQ section
Old 05-13-14, 11:14 AM
  #60
Travisbjr
Travisbjr's Avatar
Found it. Thanks This really brightened up the interior.
Quick Reply: New Interior LED Upgrade Mod
