2013 LS - F SPORT PARTS - TRD Japan
Lexus Connoisseur
New 2013 Lexus LS F SPORT Parts - TRD Japan.
The aero parts are only available for the factory "F SPORT" version of the LS.
![](http://www.trdparts.jp/lexus/common/img/carname_ls.gif)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/559655_10150250102304960_1443144060_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/250505_10150250102294960_1852851812_n.jpg)
![](https://sphotos-b.xx.fbcdn.net/hphotos-snc6/246582_10150250102284960_2041821065_n.jpg)
![](https://sphotos-b.xx.fbcdn.net/hphotos-ash3/554270_10150250102269960_1121318658_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash4/486727_10150250102394960_756633207_n.jpg)
![](https://sphotos-a.xx.fbcdn.net/hphotos-ash3/577412_10150250102384960_131057370_n.jpg)
Credit: TRD Japan
Credit: TRD Japan
Lexus Connoisseur
![](http://www.trdparts.jp/lexus/ls/image/title_price.gif)
Front spoiler
※ 1 MS341-50001-A1 One 94,500
· Color name: White Nova glass flakes (083)
MS341-50001-C0 One 94,500
· Color name: Black (212)
MS341-50002-00 One 89,250
- Bodies (Surfacer finish)
Side spoiler
MS344-50001-A1 One 73,500
MS344-50001-C0 One 73,500
MS344-50002-00 One 68,250
Sports muffler &
rear diffuser
※ 2 Painted
336,000
· Sports muffler and
a set of rear diffuser. Simultaneous wearing with mudguards (dealer option) is not possible.
Sport
muffler MS153-50001 One 210,000
· Sport muffler and
rear diffuser is installed at the same time required.
Tail end: φ76
: Stainless Steel Material
Rear
diffuser
※ 2 MS343-50001-A1 One 126,000
· Sport muffler and
· Color name: White Nova glass flakes (083) and the mudguard (dealer option) can not be installed simultaneously.
MS343-50001-C0 One 126,000
· Sport muffler and
· Color name: Black group (212) and the mudguard (dealer option) can not be installed simultaneously.
Foundation
330,750
a set of rear diffuser. Mudguards and (dealer option) can not be installed simultaneously.
Sport
· Sport muffler and
Tail end: φ76
Rear
diffuser
※ 2 MS343-50002-00 One 120,750
· Sport muffler and
Name-color: green body (Surfacer finish) with mudguards (dealer option) can not be installed simultaneously.
20 inches
forged aluminum wheels
and nut set
※ 3, ※ 4 Alloy Wheels
& nut set
630,000 ○ ○ ○ ○ One-minute
(+ security wheel nuts set of 4 wheels)
20 inches
forged aluminum
wheels MS213-00046 Four 149,100 ○ ○ ○ ○ Corresponding to one-
size: 20 × 8.5J: (thirty-five inset)
11kg: Weight-
245/40R20: tire size and recommended
Gunmetal: color
Wheel
nut
set MS212-00003 One 33,600 ○ ○ ○ ○ One minute,
16-lug ×
security lock nut × 4
-lug socket for 1 ×
1 × for security lock nut socket
with a resin case, dedicated
○ · · · can be mounted
can be mounted according to the conditions of Remark vehicle △ · · ·
except for some products ※, check whether simultaneous wearing with "Moderisuta parts" and "Lexus genuine goods" is not done in principle.
(For items that are taken to confirm whether some are set forth in detail in the remarks column.)
※ 1: Approximately 7mm down from the original ground level
※ 2: Down about 25mm higher than the original ground
Upon installation, it needs to be modified bumpers and plastic parts.
※ 3: Attached to the wheel center cap genuine separately: TPMS and valve (recommended for "F SPORT") is required.
And the use of TPMS valve (for "F SPORT") can be fitted as standard wheel center cap genuine products.
The price set contains only security lock nut set.
※ 4: Tires are not included in this product. Separately, the tire: You will need (recommended size 245/40R20).
Care instructions because there is a danger of serious accident or failure lead to remodeling after the purchase ●, please do not absolutely. ● It may not be available at the location specified by the installation of a garage jack parts. Please be forewarned. <Aero Parts> If you install a ● aero parts, the clearance between the road surface is narrow, such as a curb step, it is easier to interfere with the road surface, such as slope. In addition, there is a possibility that while traveling or during snow Russell, aero parts may be damaged if used in the state (icing) freezing. ● For painted parts, you may be the color of the paint does not exactly match the standard car. <Sports muffler> If you install a muffler ● Sports, clearance between the road surface is narrow, such as curb step, it is easier to interfere with the road surface, such as slope. You also might want to change the sound quality, and performance. Sport muffler is sometimes the nature of the material, or by heat discoloration, rust is generated on the surface. <Alloy Wheels> If you have installed, ● Aluminum Wheel Set (mounted at Tire Dealers) and the road surface freezing snow-covered road and drainage in a rainy day or increase the driving sound may grip is reduced. In addition, it may ride comfort and steering stability is different from the standard vehicle. ● Hami out, when the tires of tire size than specified, there is a possibility of such interference. ● Please make sure when punk automotive, security socket and lock nut socket for lug nuts that are included with the product as it will be needed.
Credit: TRD Japan
Lexus Connoisseur
Just for reference, the wheel set with locks is 630,000 JPY or $8072.75 USD.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Lexus Connoisseur
Does the addition of these parts/accessories (i.e. front spoiler, side skirts, etc.) reduce ground clearance?
So if I live in a place with LOTS of potholes, humps/speed bumps, then I must really drive carefully then (?)
I'm not a big fan of those looks. It's like trying to transform a transatlantic into a speed boat. Kinda like having a Bentley GT Speed. It's still a transatlantic... heavy and slow for "sport" standards. But it's a valid attempt, even though it has zero appeal to me.
Lexus Connoisseur
Despite being add on parts, i'm glad TRD Japan is embracing the Lexus aftermarket more.
Nigel-JDMParts
Club Lexus Vendor Marketplace
67
12-11-15 02:23 AM
flipside909
08-23-14 02:30 PM
flipside909
10-02-13 11:07 AM
