question about infrared heat sensors for rear passengers on ls 600hl
I have "heard" about infra red heat sensors for rear seat passengers on the LS 600.
Can someone please elaborate? How does that work.
thanks
thanks
i believe it is only for vehicles equipped with the Executive Seating Package, which is also available on the 460L.
The infrared body temperature sensor (not to be confused with radiant heat sensor for the rear a/c) measures the body temp of rear passengers on the lap, body, and face i believe - it will then make any necessary adjustments to maintain the occupant at their desired temp setting.
What I don't understand is - I can set the temperature I desire, in the rear seat control. Lets say I set it for 72 degrees. What exactly does the infra red system do for me? I have already set the desired temperature.. Does infra red sensor change the fan speed? I can't figure it out.. Because even if there are no passengers on the rear seat, I suspect that the car will maintain the same 72 degrees in the rear also.
the sensors are located on the headliner, they look like faint red LEDs sort of. If I am not mistaken, it helps the A/C system to faster regulate the temperature and keeps fluctuations to a minimum (as explained to me by others). And you do not need the executive seating package to have this, I have it in mine and I don't have exec seating
Or is it that the infra red sensors simpy sense the "ambient" temperature in the rear seat area?
Just curious.. whether or not the body temperature is being monitored.. because.. of clothing.. I am guessing that the infra red would measure the ambient temperature - infra red being more "active" than a simple temperature sensor elsewhere
I assume you are referring to Infra red sensors? Does it actually take a measurement of our body temperature? Meaning - if there is no one there, would the temperature variation be more than if there is a human?
For both the LS460L and the 600HL:
Only the Executive pkg has the infrared body temp sensor which measures the rear occupant's body temperature to make changes as well as the radiant heat sensor that all models with rear AC share. It is only referenced in the Exec pkg literature on Lexus' own website. The rear seat upgrade models do not have the infrared body temp sensor. See proof below:
See page 8
http://pressroom.toyota.com/article_...rticle_id=2576
See page 9
http://pressroom.lexus.com/article_d...rticle_id=2657
In all models with rear a/c (4 zone) there is a radiant heat sensor that measures the heat gain from solar rays and will make changes to cooling based on increased heat hitting the rear sensor. The front has its own radiant heat sensor at the top of the dash close to the windshield which will send data to the front AC.
See page 8
See page 9
See page 8
See page 9
HoleinOne
09-24-02 01:54 AM
