Air Runner on LWB
Old 11-02-12, 11:16 AM
whitetooth
whitetooth's Avatar
Originally Posted by brianlin87
after M/C = after minor change.
Take a look at the 2010 LS600 front grille.
What I'm referring to is that Nat must've custom fit the 2010 LS600 front grille without changing out the 07/08 headlights/bumpers. Either way, some serious detail going on here.
It is the WALD replacement grille as the 2010 LS front grille is different. Here is mine in black:
Old 11-02-12, 01:18 PM
CJITTY
CJITTY's Avatar
Originally Posted by Nat
My LWB was equipped with air suspension. Removing the OEM air requires a special tool.
Wire cutters But for real, your LWB is off the chain!!!!
Old 11-02-12, 01:47 PM
brianlin87
brianlin87's Avatar
You're right. That looks nice.
Old 11-02-12, 03:20 PM
lbintab
lbintab's Avatar
They could've used those to cut the air hose but they wanted to make it reversible
Old 11-02-12, 04:24 PM
brianlin87
brianlin87's Avatar
For those of you who are wondering, the tool that is needed to remove the OEM air suspension looks like the small picture at the bottom of this pdf:
http://www.youzealand.net/parts/hybrid/pdf/readme.pdf
Old 11-02-12, 04:45 PM
mk4umha
mk4umha's Avatar
The OEM ECU doesn't throw a code with out the OEM air?
Old 11-02-12, 04:57 PM
brianlin87
brianlin87's Avatar
If the car was equipped with OEM Air Suspension, the ECU will most definitely throw a code once the suspension is removed.
Old 11-02-12, 09:34 PM
Falbz
Falbz's Avatar
Looks sick !!!!
Old 11-03-12, 10:15 AM
whitetooth
whitetooth's Avatar
That's why I installed the Datasystem Controller and not the Air Runner. There is no longer a regulation while cornering, accelerating, braking. And how about ride comfort settings? All is off or am I wrong?
Old 11-03-12, 03:48 PM
lbintab
lbintab's Avatar
I replying for Nat. The info screen on the cluster does say something about the aire system. He did have the Datasystems controller but it takes a while for the car to go up and down. Eventually the stock shocks will go and replacing stock air shocks is way more expensive than your usual shock swap. Having the air runner on the ground system will let him ride low and have a good ride still. And it lets you slam the car parked which the data systems does not. Not this low.
Old 11-03-12, 04:08 PM
CJITTY
CJITTY's Avatar
Does the air runner setup help us AWD LS's to go lower or would we still have the limiting issues going as low as the non AWD's can?
Old 11-03-12, 04:10 PM
CJITTY
CJITTY's Avatar
That is the tool? Interesting ..it looks like a broken bracket or something
Old 11-04-12, 02:25 PM
brianlin87
brianlin87's Avatar
Any questions you have about AR suspension I would suggest recommend contacting Shin at ACC directly.
Old 11-06-12, 09:59 PM
chrispy
chrispy's Avatar
Nat, it was nice meeting up with you again the past weekend. Your car looks amazing!
Old 11-19-12, 01:00 AM
phenomeno
phenomeno's Avatar
Default inspiring bro
Ride looks better than ever man. Remember u promised me dem VIP modulars next year when ur done with dem hehehe.
Quick Reply: Air Runner on LWB
