Anyone take their LS460 to a Toyota dealership for oil changes ??
Hey guys, I was wondering if any member take their cars to Toyota for oil changes. How was the service? Any issues with filters or turning off the service lights on the dash? I hate the two Lexus dealership around me and have been going to Scottsdale but to avoid driving 25 miles for oil changes I was thinking to take it to a local private shop but I feel like I would still trust a Toyota tech over a guy who works on everything. When I called the gentleman on the phone said it was no issue at all. Just wondering if anyone else has done this ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Thanks
Thanks
do you guys take your own filters or are the oil filters for the Lexus and Toyota V8s the same part number?? Thanks for your help guys. This is going to save me a lot of time. If I have an issue with the car I will take it in to the dealership but for something as simple as oil it will be much much more convenient to take down the street to the local Toyota crew
Some folks have had success, others (like me) had issues. I saved myself any grief by asking questions. when they insisted my LS460 required 5 quarts, I left!
Here are some other discussions about this topic
https://www.google.com/search?q=LS46...w=1843&bih=812
CJITTY how much oil does the LS take?? I will buy the oem filters from the dealership and the oil if needed. What weight oil does Lexus recommend?? 5w20 or 0w20??? and how many quarts is required?
Lexus filters are Toyota filters and thus, your Toyota dealer will have the correct filter in stock. The part number for the filter is 04152-YZZA5. Regarding oil, the manual states: "SAE 5W-20 or 0W-20 motor oil may be used. However, SAE 0W-20 is the best choice for fuel economy, and good starting in cold weather." The Toyota dealer will have the same oil that your Lexus dealer has. Your engine requires 9.1 quarts of oil.
Yes, and successfully so.
For 83 bucks all 9 quartz of synthetic 0-20 plus the filter.
I think they made on me about 5 bucks or so ($7 oil X 9 quarts plus filter and env disposal fees, taxes).
Very happy with the service - just make sure you book the first appointment of the day - Toyota is understaffed in comparo with Lexus - and you are out in one hour or less.
I wonder whether I can give them a brake job, didn't decide if it is a good idea.
Good luck.
Good luck.
yuuuuuuup $39.99 !!! It took 15 minutes for a Rep' to welcome me. I talked to the key-boy the whole time and came to the conclusion that that's the $60 difference between them and Lexus. But I wasn't there to shoot the ish. Took 45 minutes.
$39.99 seems real cheap.
Was that for 9.1 qts of Toyota 0W20 synthetic, Toyota filter and gasket?
I would think that material cost alone would exceed $39.99
JR
I don't see how the guy commenting above can get 9 quarts of synthetic and the change for $60.
I always do my own change.....it's straight forward except for the special tool you need to take off the filter.
It takes 9.2 quarts. Use 5-20 unless you're in a very cold area.
I took my car in to Toyota since they charge $69.95 instead of $129.95 for the same service. I thought we had it all straight, as I explained to the oil change department manager how much oil it took, not a disposable filter, etc. I was in and out quickly. I DID NOT dip-stick my oil which was MY mistake. I drove the car on about a 1,000 mile trip and had a "Vision" I needed to check my oil. It was down to the ADD level. I took it back to Toyota and they "GAVE" me anothe quart of 0-20 Toyota Oil to "top it of." They charged me for 7 quartss of oil at the time of service. I see now it holds 9.1 quarts. I'm not unhappy with them, but from now on I'll dip-stick the oil before I leave their service drive. That was for PURE SYNTHETIC 0-20W oil, which my neighbor says to use. I have also been advised to NOT go 10,000 miles between changes just because you can. I've been advised to do 5,000-6,000 MIles and change it again. At half the price Lexus charges, that's reasonalble.
I had a noise in the front of my car recently after having it aligned and my FRIEND, for whatever reason, opened the oil filter door and found the Toyota Technician had left a oil filter wrench on my filtter. My friend's gain, Toyota Tech's loss.
As for me, I will continue to go to Toyota to get my oil changes done. BUT, I will make sure they know how many quarts I expect and dip-stick it before I leave.
That's half-price of Lexus, so we can afford to have it done more often.
Good luck,
Carnut
Forgot to say, Toyota gives a free car wash with all oil changes. :-)
