Work wheels and have TPMS/ valve stem air leak..
The car has stock sensors on work D3S wheels. Two of the tires on the car go flat after driving or sitting over night. The car was fine for around two years, and all of a sudden this started to happen. My Cousin found out when he slightly moved his valve stem he would hear a little bit of air leak out. Sooo, Is there a valveless sensor he can strap on his wheels that the LS460 will read after programming? Then just use work valves and not worry about the leak. Thank you
Salil022
03-02-15 06:45 PM
