2007 Lexus LS460 Bluetooth Music Streaming Question.....
So I currently have a 2006 Lexus GS430 and was wondering if the 2007 model LS460 came equipped with streaming music through bluetooth?
i found a company that made a streaming audio piece for the 07-09 460 but it would only play thru the front speakers like on phone calls.. which was a waste so i didnt post it... but i believe there should be more realistic options after CES in jan. if u dont have ML u can always try a parrot... it may work
you can use this:
http://www.amazon.com/BlackBerry-Rem...lackberry+a2dp
Several other LS owners have used it successfully. All you need is an A2DP device.
I don't think you can change the track from the steering wheel as all it's providing is blue tooth to the A2DP device. The A2DP device is connected to the head unit via the aux input.
I don't think that you can upgrade the blue tooth connectivity in the car using the factory unit. It only has one bluetooth connection. On 2010+ cars there are actually two - one for the phone and the other for a bluetooth capable music device.
Adam--Any loss of music quality over BT? I have an 09 LS Levinson and iPhone 5 and was wondering if you could post links to where I can purchase the entire BT music setup you have. Big thanks!
https://www.clublexus.com/forums/ls4...bluetooth.html
JR
hey guys here's an update for you.. isimple just released a universal plug n play piece that should fit the bluetooth bill pretty well for all brands of smart phone.. i plan on ordering 1 an doing a custom mod where its hidden an hardwired to the back side of the aux plug.. here's the link...
http://www.me-mag.com/product/item/4...etooth-car-kit
