optima baterry
Hi
i want to change the baterry to optima
which one should i take the yellow 55 amp or the red one for my ls460 07?
By the way it has 80 amp on the car
thankssssssssss
thankssssssssss
DO NOT GET THE YELLOW TOP!!!!!! get the RED TOP... the part # is SC34U its 1000ca,800cca the major difference is the yellow will only take up to a 5-10amp charge (as it is a true deep cycle battery even the yellow starting version) the red top is a true starting battery an will take 30+amps and will recycle a lot faster than the yellow..
most people think the yellow is the better battery but its only better if u plan on sitting in parking lots (engie off blasting music) or car shows all day.. then trickle charge the battery back to full when done (8hrs fyi)
