OEM Air Suspension ride height links below car..adjustable?
#76
Unless I missed something, the original post did not mention what year LS400 he had? Also, are you talking about adjusting the factory air "adjustment arms" while also using an aftermarket controller or just by itself?
I have a 98 LS400 and I dialed mine all the way down a few months ago and i got a nice 2" drop from the factory system. One strange thing is... no matter how much I play with it, the drivers' side is still 1" higher. Any ideas out there? Hiroshi
#79
It is not rocket science to figure out, and I am sure I am not the first to try this, but...in order to get the car as low as possible using the OEM adjustment arms you have to get the arm lower than the factory settings will allow. I made a short bracket for each corner which effectively moved the arm position about 1/2" lower and the results are obvious. Only problem is the car rides like crap since the air bags are almost completely deflated - but I expected that.
I was hoping that in this position I could cheat and use the "Hi" setting when I want to return the suspension to a more driveable height but that didn't work. So, this mod is not ideal but it sure looks good and as long as the bags don't blow...I'm happy with it. Cheers. Hiroshi
#80
I lowered my car like that when I was having the module issue. I removed the 10mm bolt, straightened the tab that falls in the hole, then turned the tab so that the sensor drops (cant remember which way it was turned but the sensor drops) and tightened it to where I wanted it. It only takes a small move for the car to lower a lot. Took about an hour of turning, checking, loosening, retightening and checking again before I got it to where I wanted it which was about the same as 4 on the module. Raises to about stock height when the high height button is pushed. I've since resolved my module issue, so I set everything back the way it was.
Thx in advance.
#81
just got my 08 ls460L.
i want to get rid of some of the gap as well.
whats the best way?
whats the easiest way?
whats the most affordable way?
anyone have info on the lowering modules to look at?
any for sale?
I think i read there is a wireless one. I don't want to see the module at all if possible.
whats the best way?
any for sale?
#82
whats the best way?
any for sale?
whats the best way?
any for sale?
http://workshop-manuals.com/lexus/ls...ion/page_7414/
#84
what is the module number?
I hear their is a wireless remote model of some sort.
I don't want to see the unit. I prefer it to be as integrated as possible or not visible at all.
thanks
#86
I have learned that for a 2008, there is no wireless option available. Bummer. Guess I'll have to do the glove box install.
#87
My wired data controller does the job just fine..cheaper too. Wired version works with 2007-2014 and most likely 2015 models, contrary to what vendors will tell you. I have personally seen the ASC680L work in two 2013 LS F Sport models
#88
Found out today I can take my car to Lexus get them to trick the factory air suspension. $375
Not sure if this is the right place to post this. If not, let me know where I should.
Saw it on one in their showroom with 22" Vossen. No wheel gap at all.
Couple days later when I went back to get a pic, it was gone, sold.
#89
