tapping rear view mirror for power
Old 03-31-13, 09:45 PM
rusamur
rusamur's Avatar
Default tapping rear view mirror for power
Anyone has any pointers on tapping the rear view mirror to power a dash cam (or a radar detector) in a 2013 LS? I want to avoid running the wires all around to the power plug. As much as a read, prior to 2013 have a little plastic thingy on a mirror that slides out, which makes it easier - the 2013 is all enclosed. thanks!
Old 04-16-14, 02:33 PM
philj
philj's Avatar
i would love to know the answer to this question.
Old 04-16-14, 03:55 PM
CJITTY
CJITTY's Avatar
Probably have to tap under headliner where wires are accessible
Old 04-16-14, 04:05 PM
peteybabes
peteybabes's Avatar
My brother pried apart his mirror to install his built-in radar behind/inside his mirror so that it shine through the front. it is very risky, but very clean looking.
Old 04-16-14, 06:11 PM
sktn77a
sktn77a's Avatar
You can tap into either the homelink panel:
https://www.clublexus.com/forums/ls4...001-ls430.html
(this is for the LS430 but they are all similar)
Or the mirror, but don't pry the mirror apart!
http://store.blendmount.com/mirrorta...-460-p829.aspx
Old 04-16-14, 09:47 PM
mishutka
mishutka's Avatar
When I was researching on Blendmount mirror power tap, I found that not all dash cams have identical power jacks. This prompted me to halt hardwiring dash cam.
Old 04-17-14, 06:59 AM
sktn77a
sktn77a's Avatar
Yes, you will get 12 volts from any power source in the car (except a USB socket). Some dash cams use the 5 volt USB voltage while others use the 12 volt car voltage. Good point!
Old 04-17-14, 10:57 AM
jamodeo
jamodeo's Avatar
This might help with removing the map light part for our 13'
-Joe
Old 04-17-14, 11:05 AM
jamodeo
jamodeo's Avatar
And this:
-Joe
mhussien32
06-24-19 08:35 AM
Badasilva1
08-16-16 12:42 PM
pman6
06-25-16 04:22 AM
VinayRaju
07-22-14 01:34 PM
PFB
08-31-10 08:27 PM
Quick Reply: tapping rear view mirror for power
