Old 01-09-15, 03:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior
Print Wikipost
change engine air filter LS 460
Old 04-25-13, 03:40 PM
byroncat
byroncat's Avatar
Smile change engine air filter LS 460
Does anyone know how to change the engine air filters on a 2007 LS460?
Old 04-25-13, 04:04 PM
Lextrician
Lextrician's Avatar
Yeah pop the engine cover off loose the strap with a pillips or 10mm socket pop the clips and replace
Old 04-25-13, 05:18 PM
Tee
Tee's Avatar
It's mad easy dont forget to shop vac any debri in the box then reset the filter mileage to 15K.
Old 04-25-13, 08:29 PM
PRSUIT460
PRSUIT460's Avatar
No tools needed. Pull up on the engine cover, unlatch the latches that hold down each air box. I think there are 3 on each lid. Like Tee said, vac up the debris in the bottom of the air boxes. Reverse process..
Old 04-26-13, 09:09 AM
byroncat
byroncat's Avatar
Smile How to change engine air filters on 2007LS460
Thanks Guys,
Like most things it's easy if you know how; thanks for the tip about using a vacuum in the filter box.
Byroncat
Old 04-29-13, 02:15 PM
RA032023
RA032023's Avatar
You do need to slip loose the two input hoses, if I remember correctly. I think they are (or should be) secured with hose ring clamps. It is amazing what collects in those boxes!
Old 08-03-14, 10:11 PM
YDSLexus
YDSLexus's Avatar
Default 2007 LS460L air filter and throttle cleaning procedure
See my procedure to replace engine air filter and throttle cleaning. I uploaded a file and don't know I have typo. Thanks.
sktn77a
03-25-14 07:45 PM
lbberman
RX - 1st Gen (1999-2003)
01-03-12 01:25 PM
billhinatl
05-03-11 07:33 PM
rduncan265
05-18-07 11:41 PM
plong
01-17-04 08:35 PM
Quick Reply: change engine air filter LS 460
