Lexus LS Grille Options
Old 02-24-14, 01:50 AM
  #31
Shibumi1
Shibumi1's Avatar
Originally Posted by roadfrog
Shibumi:
Another question (and apologies to the OP for hijacking).....What did you use to fabricate the grill pieces?
abs plastic w some zip kicker (modeling glue with accelerator) then aluminum strips underneath for strength.. molded in with kitty hair (aka duraglas bondo/fiberglass mix)
Old 02-24-14, 07:08 AM
  #32
roadfrog
roadfrog's Avatar
Thanks Shibumi
Old 02-24-14, 02:00 PM
  #33
WhitBaby
WhitBaby's Avatar
Still mousing around with grill options. I'll probably go with one of these two. The red car doesn't really lend itself to look as good as Roadfrog's black. I wanted black or white but wifey wanted red...so we got red.
Attached Thumbnails Lexus LS Grille Options-grill-4v3a.jpg   Lexus LS Grille Options-grill-4v1a1.jpg
Old 02-24-14, 02:59 PM
  #34
1Putt
1Putt's Avatar
2nd is my vote
Old 02-24-14, 06:07 PM
  #35
Tee
Tee's Avatar
Here's a pic of my grill from last summer photoshoot.
Old 02-25-14, 07:41 AM
  #36
roadfrog
roadfrog's Avatar
Yeah TEE, that looks great!
The beauty of the Plastidip is that any modification is easily changed/removed.
I'm intrigued by the ide of blacking out the circle around the "L". I may give it a go and see. Then, if I don't like it, I'll peel it off.
Old 02-27-14, 08:46 PM
  #37
scottkroug
scottkroug's Avatar
^^^^ agreed that looks real good
Old 04-05-14, 10:24 AM
  #38
WhitBaby
WhitBaby's Avatar
How do you get the '08 grill out???
I removed the bolt and about 8 clips, but it still seems anchored along the bottom somehow.
Old 04-05-14, 10:29 AM
  #39
Shibumi1
Shibumi1's Avatar
Chk my thread on the nike light swap.. I know I posted pics..
https://www.clublexus.com/forums/ls4...lb-swap-2.html
Old 04-05-14, 10:32 AM
  #40
krypto89
krypto89's Avatar
if you took out all the plastic bolts, it might be just one of the clips running along the sides and the bottom that might be still holding the grille on. sometimes when you un-clip one, the others you took off might re-clip back. just continuously make sure all the clips are undone and shimmy it back and forth and it should come off...
Old 04-05-14, 10:44 AM
  #41
WhitBaby
WhitBaby's Avatar
Thanks guys and found shibumi1's pics.
I guess I'll just have to 'finesse' it a little firmer. I couldn't get any feeling of retention from the 5 tabs. I thought they were just indexing/positioning tabs for installation.
(Later): OK, GOT IT, thanks again!!
(Later, later)
Was going to separate the inner grill from surround, but looked like there were ten more tabs locking it on. Decided not to push my luck and just removed the whole grill and masked everything. 1st coat drying now.
Old 04-05-14, 01:34 PM
  #42
WhitBaby
WhitBaby's Avatar
That's kinda what I ran into trying to separate the inner grill from the surround.
I suppose I could have used ten shims to keep the latches from relatching as I moved from one to another, but wussed out and masked it.
Fourth coat drying now.
Old 04-05-14, 04:23 PM
  #43
roadfrog
roadfrog's Avatar
That's the beauty of Plastidip. You don't really need to remove the center OR even be too careful masking. I found my center came out super-easy, but whatevs....
Old 04-05-14, 04:52 PM
  #44
CJITTY
CJITTY's Avatar
I popped my grill out to spray it and at least a year later..it looks the same. I love that plastidip
Old 04-05-14, 04:55 PM
  #45
1Putt
1Putt's Avatar
+1, although a much smaller area, plastidip held up extremely well on the kidney grills of my previous BMW E39 540 and the 540i emblem on the trunk lid
Quick Reply: Lexus LS Grille Options
