DIY brakes
Not sure if there's a DIY thread on that but I posted this some time ago. You basically pull the wheel off, and remove the clips that hold the pins. Then the pins slide out and the pads slide up and out. New ones go it and everything in reverse. Once I sat my car down, I turned it on and it almost seemed like it recalibrated it self. I didnt do any brake bleeding. Check down a bit on the thread attached and you'll see what it looks like. All 4 wheels are the same.
https://www.clublexus.com/forums/ls4...his-forum.html
Lexmex
RX - 1st Gen (1999-2003)
49
10-29-16 08:02 PM
