DIY Replacement of Seat Filters?
#31
I'm going to check my filter, I don't think my seat cools as well as it should.
Best quote on CL yet. And I'm in agreement 100%!
#32
I used the seat cooling feature for the first time about a week ago.
As I've never had a car with this feature, im not exactly sure what I should be feeling or rather just how it supposed to work in its most effective state.
What I did feel was like a cool sensation on the under portion of my thighs and coolness on my lower back. But to be honest, im not sure if this feature was used on a really hot day, I would get much benefit out of this feature.
I'm almost positive the 460 has this feature, because when I was shopping for an LS and looking at the myriad of MyLexus maintenance histories, I came across two different vehicles where the customer had complained about the functionality of their cooled seats, and the tech noted that they "Cleaned seat filters"
I guess the only thing I can do is pull mine out and take a look at it. Clean it out or replace it if need be, then try the feature out again.
Has anyone cleaned theirs out/replaced it and found the cooling element to perform better?
#33
I use mine all the time in the Summer. I have a dark blue uniform and when I'm off duty and I get into my car and feel that nice cool air.....it makes the commute so much nicer. Even better if I use my remote start and get the seats cooled before I get in.
#35
So I was chit-chatting with my butt earlier today, and it said something that got me thinking. My butt said, "as you know, I deal with some very low quality and sometimes even dangerous air, so it's not the quality of the air that I find important, it's the quantity."
I didn't think much of that statement at the time, but I just had a thought. What if I remove the filter and just leave it off? My butt doesn't care about the quality (filtered), it cares about quantity. Maybe without the filter it would be less restrictive and blow more quantity. That would make my butt happy!
Plus, I get the feeling that the filter may tend to filter my flatulence aroma. No man wants that ... we prefer to SHARE! I'm going to take it off and see if I get more flow.
To be honest, I have yet to let one slip in the LS. The car still smells new. I don't want to ruin a good thing.
7milesout
7milesout
#37
I just did. I took pics but it will be tomorrow before I can post them because I need to compress them. But I will describe. It is fairly centered under the seat. It's about the size of a cup (where you'd put your mouth) in diameter. It has shaggy white foam sticking out the bottom, and a black plastic ring ... which is what is about the size of a cup in diameter.
I had to sit on the garage floor, move the seat mostly forward and as high as I could get it. If you shine a light you can see the shaggy white foam barely. Put your hand in there and twist the whole thing by the plastic and it comes off. Mine looked very clean ... not flatulence laden at all. I doubt it will flow more air but I will check it tomorrow.
7milesout
7milesout
NYCProdigy (07-09-20)
#39
There isn't one in the LS600h right? I can find the fan in the parts diagrams but no filter. Haven't looked under the seat yet (my son is driving the car this week - his g/f is up to visit) but I'll look this weekend. Just wondering if there's a point. I have the heated & cooled rear seats but not sure based on the parts diagrams if they're filtered like the 460.
#40
Tinkering on 07 LS460 we picked up yesterday and found rubber air tube to drivers seat bottom pulled off of the plastic elbow that feeds the cooling "element". I had to unbolt seat and tilt it up to get some room to work so I snapped a pic of the filter that is attached to the fan. It had a small piece of cloth tape that I peeled off before it could be turned and removed. (1/8 turn). Vacuumed it off and reinstalled .
The following 3 users liked this post by trbolvr:
#41
![](http://acurazine.com/forums/images/smilies/nono.gif)
#42
![DIY Replacement of Seat Filters?-image.jpg](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/361862d1461374067t-diy-replacement-of-seat-filters-image.jpg)
If I did this correctly you were able to see the dirty filter and the new filter, they arrived today and it literally took me five minutes to replace both filters on each side of the seats. I removed my weathertech mats pushed the seats forward. When my hand was underneaththebseat you can feel the small filter piece, give it a light twist and they came off. Then, I twisted the new filter on pushed my seats back into the normal position and put back my weathertech mats. I will see tomorrow if it makes a difference either way the filters are clean and new I also noticed to get more air to the driver seat last summer I decided to unhook the rear carpet on the back of the front seats and it directed the air when it was on the floor up to the seats fan and my back and bum stayed a lot cooler :-) it seemed to work and or was super easy to do. GOOD LUCK GANG!!!!
glerobi (10-16-18)
#43
You suckers beat me to it! But I'm going to post my pictures anyway.
Also, it really did seem to cool better without the filter. I did feel more air. However, the car was cool from being in the garage, and it being morning. When I drive out to lunch today I will reconfirm. I may wind up going filterless. My butt did prefer this morning's air flow performance.
glerobi (10-16-18)
#44
