Is there a "plug and play" remote start solution for LS 600hl?
Is there a remote start module with android app for a 2008 LS 600hl?
For example, http://smartkeystarter.com/ has an amazing solution for Mercedes. They just plug it in, behind the dash - I think no wires are even cut. You just use the standard key's panic button to start the car (or phone app). No separate remote for starting..
They just unplug a harness in the dash and plug in their harness inbetween and install a bypass switch to bypass their entire module with the flip of that switch (they suggest that the switch be flipped to bypass, if the dealer has to update the car's software).
Is there such a simple solution for the LS 600 HL?
I had remote start systems installed in my ES 350s and RX 350 and a friend's LS 460. Friend's LS 460 had problems, which needed a couple of visits to the remote installer. Those solutions involve a lot of wire splicing.. and I don't want to go through all of that.. Seeking a solution similar to the smartkeystarter.com...
