Stabilizing fins. Possible fix for wind noise in pre 2013 cars.
#61
This part is actually the part for the 2013/2014 cars, but yes, this fits all LS 460's
I have driven my car with the jmcraney fix in place and up to 30 mph it is almost silent with tire and engine noise much more pronounced. at around 50/60 mph there is the same old noise as before which i hope these new fins will eliminate.
I be back with an update soon!
#62
How do these attach?
here is a link to these items:
http://lexus.sewellparts.com/accesso...2013/6707.html
remember to log-in for the best price of $18.30 each. . .
#63
If you are going to simply install these without the jmcraney fix, then just refer to page one of this discussion.
I have not installed mine yet, but plan to do so in a few days after the jmcraney fix has a few days on my car.
#66
Change all the rubber around the windows helps the most. I did the jc fix and the fins the one that made the best change at higher speeds was the weather seals.
#67
how involved was the seal replacement? And would you have the part #'s off hand?
**another quick note on the status of my fix. this sealant does not work in the cold weather we've been having, even in my garage where it gets to 45 degrees or so. i will tackle/finish this project tomorrow with some 5-minute 2-part epoxy**
#68
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
We've understood for a long time that the "wind noise" problem is an international problem but not too many reports from Down Under. Welcome to the CL discussions.
If you are unable to secure the new parts, here is something you can try with the parts that you have now: https://www.clublexus.com/forums/ls4...noise-fix.html
Seeing how we hang upside down off the planet and the toilet water goes backwards down the hole, who knows what may happen!
Cheers again from Downunder!
#69
#70
#72
#73
#74
