Avest/SpecD LS460 LED Tail Lights
Old 05-11-14, 08:26 AM
  #316
CJITTY
CJITTY's Avatar
Originally Posted by lieup
So after several adjustments, I can't still get my passenger side (top big tail light NOT small piece) to fit flush like the driver side. It's hard to see but if you open the file and highlighted it will give better view. See image for more details. I think this tail lights will look much better if all the LED's activate. I might look into the optional kit that will allow you to have this features. I will look into this item and let you guys know. Overall, is not bad for the low cost upgrade with new look.
Tips: Make sure you mask all around the tail lights when you do this install to prevent scratches.
I'm confused. All of my LEDs activate...what are you referring to
Old 05-11-14, 09:00 AM
  #317
lieup
lieup's Avatar
Default LED tail lights
Like this! I think the optional kit allow this feature.
Attached Thumbnails Avest/SpecD LS460 LED Tail Lights-led.png
Old 05-11-14, 10:59 AM
  #318
CJITTY
CJITTY's Avatar
When my lights are on and I brake, it looks exactly like this already. .so not sure what this optional kit truly does
Old 05-11-14, 11:04 AM
  #319
lieup
lieup's Avatar
It allow you to have that look without stepping on the brake.
Old 05-11-14, 11:05 AM
  #320
CJITTY
CJITTY's Avatar
So what happens when you actually brake? Do they get even brighter or how will folks distinguish the difference? I personally like the acrylic glow for running lights and the two rows come on to really alert others you are braking.
Old 05-11-14, 11:07 AM
  #321
CJITTY
CJITTY's Avatar
This is how mine look while braking with lights on..same look as optional kit as you describe. So unless the brake lights get even brighter with this optional kit, I would pass on it..I want folks behind me knowing I am braking. The glow of the tubes as running lights are plenty bright and looks better than all of them on just for running lights imo
Avest/SpecD LS460 LED Tail Lights-forumrunner_20140511_140625.png
Old 05-11-14, 11:12 AM
  #322
randomwalk
randomwalk's Avatar
urghhh...if it all lid up like that..when you brake it makes no difference. Kind of defeating the purpose and an invite for a rear-end.. No thanks.
Old 05-11-14, 11:13 AM
  #323
CJITTY
CJITTY's Avatar
Exactly. .there has to be more to this optional kit than what I keep hearing..if not..whats the point.
Old 05-12-14, 07:27 AM
  #324
peteybabes
peteybabes's Avatar
I had the opportunity to drive behind my car yesterday in bright sunlight. the brakes are bright enough, but i was a bit disappointed with the blinkers. . . could hardly see them because of the silver/chrome around it.
Also got to view the reverse lights from 65ft away in nearly direct sun and you could see the white lights and they were bright, but not Cadillac white like their reverse lights. and because i was on a slight angle i could clearly see the right reverse light but the left which was slightly angled away from me was almost not visible/definitely dimmer.
just some feedback! go do this test yourself and let me know your feedback!
Old 05-12-14, 08:51 AM
  #325
CJITTY
CJITTY's Avatar
I agree completely with turn signals...disappointed that a dodge avenger rear leds will burn a hole in your retina but ours are kinda meh on brightness. The size of our LEDs compared to like the BMW s or Avengers are way smaller. Def could be better but I can live with it
Old 05-12-14, 09:05 AM
  #326
CJITTY
CJITTY's Avatar
Installed mine on friday. 80% pleased overall with function and fitment. Like I mentioned before, turn signals could be much brighter compared to subcompact cars that have brighter leds than these.
Avest/SpecD LS460 LED Tail Lights-forumrunner_20140512_120235.png
Avest/SpecD LS460 LED Tail Lights-forumrunner_20140512_120252.png
Avest/SpecD LS460 LED Tail Lights-forumrunner_20140512_120353.png
Old 05-12-14, 09:47 AM
  #327
peteybabes
peteybabes's Avatar
Beautiful! getting ready to install spoilers as well.
At least we don't have to worry about aftermarket tails that are "pink" instead of a true red like these. Saw a dodge Caliper with aftermarket tails and his blinkers were more pink than red.
Old 05-22-14, 09:32 AM
  #328
PrinceAkim
PrinceAkim's Avatar
Originally Posted by Tdvlexo
These are not good pictures (phone)
Love the look of your car!!! So clean,
Old 05-22-14, 05:14 PM
  #329
Tdvlexo
Tdvlexo's Avatar
Thank you sir for your comment. I'm thinking about getting a new set of wheels and I am converting my stock air to coilovers.
Old 05-27-14, 12:39 PM
  #330
PrinceAkim
PrinceAkim's Avatar
I thought about that for a moment as well. If my struts start to blow, I may do coils in the future. Loving your body kit!
Quick Reply: Avest/SpecD LS460 LED Tail Lights
