F sport air intake sound generator DIY install (10 minutes)
Old 07-26-17, 04:32 PM
Nguyenazn
Nguyenazn's Avatar
No video sound clip ?
Old 11-16-18, 01:09 PM
whytry
whytry's Avatar
I'm interested in the mod, too. Just want more sound from motor, have Oliver mod done, but want that WOT sound too. Can someone better describe where the silencers are that they are talking about taping off?
Old 11-16-18, 01:30 PM
RocketSlug
RocketSlug's Avatar
On my 07 and 12 LS it's the lowest part of the intake, and the farthest forward. Looks like a black plastic WWII German stick grenade. Its sole purpose is to reduce intake noise for a more luxurious and quiet acceleration. The F sport one is tuned to do the opposite, and prob sounds different than my solution
My thinking was that I have another thing blocking or absorbing air that is not needed so why have it? I didn't pull it off because it does support the lower intake tubes.
Old 11-16-18, 01:47 PM
jdanielca
jdanielca's Avatar
Originally Posted by LSin75033
I got the air intake sound generator in from Sewell Lexus of Dallas today. pn# 17898-38010. Install is very straight forward, took me 10 minutes give or take. You'll need:
10mm socket
socket extension
small flathead or pick
#1 remove silver engine cover: just pull it up from the back, there's just 2 "*****" that it snaps in and out of
#2 remove front plastic cover: this is held on with 5 clips. you just need to stick a small pick or screw driver in to the inner circle and pry it up, once that inner circle pulls up a little, you can pul the whole clip out
#3 remove the intake "y" collector: there's 2 hoses at the top you need to pull off (held in with spring loaded bands), the part on each side that connects to the air filter box is attached with 2 hose clamps (10mm bolt) and 2 tabs (just pull the rubber out and over the tabs to pull it towards you on each side). there's also a wire that is connected with a push in tab on the right side of the y collector, be sure to disengage that wire before you tug the y collector out. now you can pull the whole Y collector out.
#4 remove the stock intake resonator: there's a single 10mm hose clamp that you'll remove at the middle of the neck. losen the clamp and pull the old tube out and replace it with the new noise generator.
#5 reinstall: make sure that you align the little "spike" on the sound generator with the hole so it doesnt rattle, then be sure to re-clip the wire back in to place. everything else is just reverse of removal.
just what I was looking for... dont have to get under the car right ?
909IS350
Suspension and Brakes
01-19-16 12:11 PM
i2fat
05-08-15 11:02 AM
Djtexan
IS F (2008-2014)
16
05-03-12 08:38 AM
XprincoX
Performance
25
05-23-08 11:46 AM
Bigwun07
05-07-08 07:58 PM
Quick Reply: F sport air intake sound generator DIY install (10 minutes)
