F sport air intake sound generator DIY install (10 minutes)
Old 01-31-14, 03:11 PM
LSin75033
LSin75033's Avatar
Default F sport air intake sound generator DIY install (10 minutes)
I got the air intake sound generator in from Sewell Lexus of Dallas today. pn# 17898-38010. Install is very straight forward, took me 10 minutes give or take. You'll need:
10mm socket
socket extension
small flathead or pick
#1 remove silver engine cover: just pull it up from the back, there's just 2 "*****" that it snaps in and out of
#2 remove front plastic cover: this is held on with 5 clips. you just need to stick a small pick or screw driver in to the inner circle and pry it up, once that inner circle pulls up a little, you can pul the whole clip out
#3 remove the intake "y" collector: there's 2 hoses at the top you need to pull off (held in with spring loaded bands), the part on each side that connects to the air filter box is attached with 2 hose clamps (10mm bolt) and 2 tabs (just pull the rubber out and over the tabs to pull it towards you on each side). there's also a wire that is connected with a push in tab on the right side of the y collector, be sure to disengage that wire before you tug the y collector out. now you can pull the whole Y collector out.
#4 remove the stock intake resonator: there's a single 10mm hose clamp that you'll remove at the middle of the neck. losen the clamp and pull the old tube out and replace it with the new noise generator.
#5 reinstall: make sure that you align the little "spike" on the sound generator with the hole so it doesnt rattle, then be sure to re-clip the wire back in to place. everything else is just reverse of removal.
Attached Thumbnails F sport air intake sound generator DIY install (10 minutes)-img_6057.jpg   F sport air intake sound generator DIY install (10 minutes)-img_6060.jpg   F sport air intake sound generator DIY install (10 minutes)-img_6062.jpg   F sport air intake sound generator DIY install (10 minutes)-img_6064.jpg   F sport air intake sound generator DIY install (10 minutes)-img_6065.jpg
The following 3 users liked this post by LSin75033:
Commacausi (08-29-20), joedaddy1 (07-02-20), mambo619 (03-17-21)
Old 01-31-14, 05:31 PM
lbintab
lbintab's Avatar
And the verdict on the sound?
Old 01-31-14, 05:59 PM
LSin75033
LSin75033's Avatar
not sure yet. i was putting around town with the kids in the car, so i didn't get on it. under low throttle, no difference, under medium throttle there's a little more grumble. i'll let you know as soon as i get to put my foot down.
Old 01-31-14, 09:23 PM
LSin75033
LSin75033's Avatar
now that I've driven around a bit with it, its a little noticeable under full throttle, but not by much. was it worth $110? maybe. only because its a fairly cheap mod and its OEM. if you put the car in sport mode and let the engine wind up you WILL notice a difference.
its nice because my wife will never notice that I modded the car as she puts around, but when I'm driving solo i can punch it and notice
Old 02-01-14, 06:58 PM
I8ABMR
I8ABMR's Avatar
wonder how it works. Seems like Lexus will never allow anyone who buy any oem stuff from them that will do much for sound. I had an F Sport intake on my GS350 and it sound 100% stock. Total joke in that case. What my LS needs is a sway bar set that it 2x as thick in front and 3 times as thick in the rear. The sway bars on the LS feel like coat hangers compared the ones I had on my Infiniti
Old 02-03-14, 11:35 AM
LSin75033
LSin75033's Avatar
so with just about any modern car, somewhere along the path of where the air filter is and the throttle body, there is some sort of resonator box/tube. that's all this thing is; just a redesigned resonator chamber that makes more noise than the original one. you could probably just remove it all together and put something over it (very fine mesh maybe) and get more noise.
Old 09-09-14, 12:43 PM
RocketSlug
RocketSlug's Avatar
Default Just taped over it
I used electrical tape, but yes, simply closing off the stock silencer piece gets you the good WOT and acceleration noise.
Old 09-09-14, 07:02 PM
jamodeo
jamodeo's Avatar
Could you post a picture please? I am having a hard time visualizing where you guys are talking about.
Thank you
-Joe
Old 09-09-14, 07:48 PM
roadfrog
roadfrog's Avatar
Thank you
-Joe
Post #1 has a pic the last one. At the front and middle of the motor, behind the coolant reservoir tank. Near the serpentine belt and pulleys.
Old 09-09-14, 08:49 PM
jamodeo
jamodeo's Avatar
I got that just wondering how the electrical tape setup looked.
-Joe
HushedRide (05-16-23)
Old 06-30-17, 12:42 PM
213374U
213374U's Avatar
^ Wrong thread?
Old 06-30-17, 06:48 PM
RR601
RR601's Avatar
I tried one about a year ago. Actually could hardly tell a difference at all. Ended up taking it back off.
Old 07-02-17, 08:22 AM
Chuckinnj
Chuckinnj's Avatar
Want some aggressive engine sound?....... Consider the exhaust vents that are proven to work.
Old 07-07-17, 01:35 PM
CJITTY
CJITTY's Avatar
I did the exhaust vents..got the sound I was looking for
Old 07-21-17, 01:40 PM
Oliver Enterprises
Former Sponsor
Oliver Enterprises's Avatar
Wow - I had never noticed this thread before! I wonder what this intake mod sounds like? Maybe I could make it "mo' bettuh." I was also considering a way around the permanent removal of the fixed filter elements on the intake. The U.S. has these fixed filters, but other regions do not. It would reduce some intake head loss, and increase the sound ... tastefully. I just haven't got back on that project.
Quick Reply: F sport air intake sound generator DIY install (10 minutes)
