Is there an easy way to refill the transmission?
I think I'll take it to the dealer next time, when I reach 200k.
Sealed or not
This is my understanding about "sealed" transmission. When Toyota says sealed transmission, it means that the inside of the transmission is not open to ambient air under normal driving condition. This is achieved by not having a dipstick. WS fluid is hygroscopic. If WS fluid absorbs moisture from the air, its service life gets shortened. Some Toyota cars use WS fluid but still have dipsticks. These cars, according to Toyota, need to have their transmission fluid changed around 100,000 miles. I agree that even for sealed transmission, it's a good idea to change the fluid around 100,000 miles, if you plan to keep the car for a long time.
https://www.clublexus.com/forums/8373646-post9.html
CareyP
It's imperative that the fluid level is correct for the tranny to function properly in these new model. Older model with dip stick the tolerance is more. If I were you I would take it to the dealer and pay a few bucks for them to adjust to the proper level. Since you did 90% of the work I can't image they will charge much. But again it's the stealership. Lol.
Ls-460 tranny oil
I'm approaching 100k in my 2007 LS460, so I drained the transmission fluid & assumed it would be easy to refill (just like my GS400).
Imagine my surprise when the socket wouldn't fit into the gap between the transmission case & some insulation to access the "refill plug".
A long 24mm wrench finally did the trick, but what a pain!
Any thoughts or tricks to share?
I have the WS ATF fluid, but haven't ventured onto the next steps of "Fill Transmission" & then "Adjust Fluid Level".
Thanks
Thanks
Ask your friend why Aisin, the manufacturer of the transmission, designed it to be serviced. Not to mention that in Canada Lexus instructs the 430 transmission be serviced every 60k yet in the US it's "lifetime". For those who are really serious about this subject, may I suggest taking a sample of your transmission fluid at the your next interval and then have it analyzed by a lab. It's cheap and several members in the 430 forum have done this. It will tell you exactly the condition of the lubricant. I realize that the 460 and 04-06 430 do not have the same exact transmission but they are very similar and use the same WS synthetic fluid and both lack dipsticks. Neither are sealed but have both a drain and refill port.
http://www.blackstone-labs.com
This is a great thread on the 430 side that shows some real data. I plan on doing it myself next time I have mine drained and refilled.
https://www.clublexus.com/forums/ls4...id-thread.html
DrQuality (07-26-21)
Thanks
Thanks
Check out this video @16:58
Thanks
Thanks
Check out this video @16:58https://youtu.be/6dKEMI_YFrQ?t=1015
