Little bit of light work tonight
Finally have vid uploaded of the Code3 710 installed the rears are a lot harder to get across them I imagined, will set aside a day when my strobes come in and do it all at once. When crossing the firewall, I ran 4 extra sets of wire one dedicated to power, the other is accessory power, the others are just switch wires. No more digging under the dash for 12V.
Finally have vid uploaded of the Code3 710 installed the rears are a lot harder to get across them I imagined, will set aside a day when my strobes come in and do it all at once. When crossing the firewall, I ran 4 extra sets of wire one dedicated to power, the other is accessory power, the others are just switch wires. No more digging under the dash for 12V. Video Link: https://www.youtube.com/watch?v=VJOhMagBZtA&feature=youtube_gdata_player
We can all see it Tee, we just don't want you to get any ideas! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
(It's working now chpten8).
Swapping out my low beams to a higher temp. HID as well as my fogs, and you are correct connecting HID's to DRL will mot operate correctly also when the High Beams are activated they will take 3-5 seconds to fully charge before becoming useful, results=Allbad.
"Off-highway use only" also username says it all
509IS350
06-24-11 12:32 PM
