What Causes Brake Rotors to Crack Like This?
After replaced all front and rear Akebono's advanced ProACT Ceramic pads. Result after 1K miles from both rear driver and passenger sides.
I ran those akebonos for over a year with oem front rotors and raybestos advanced technology rotors in the rear.never a problem..in fact i was very happy with them...others are running them too
Are you sure those are cracks and not just heat-checking? I can't tell from the picture. Heat checking is normal. I don't understand the concern of ceramic pads on our vehicles. ETWD....if you could explain your concerns, I'm very interested to hear! I've always run semi-metallic, but I would not have hesitated to use ceramics on mine.
My indy mechanic (Lex specialist shop) who used to be a tech at Lexus said his experience has been that our oem rear rotors are prone to warping... fwiw
could be the situation I am not a fan of getting rotors turned and instead just buying new ones when needed because maching down the material will prone them to warp. I agree with new ceramic pads and new rotors if any one choose the course. I have used ceramics before and had no problem but it was new rotors instead of old. most people go ceramic to eliminate the dust.
I have read several posts that say the Lexus rotors are prone to warpage. According to my car's service history from previous owner, the fronts were replaced by dealer last year and when I bought the car in January, they were warped again. I purchased a set of Bendix rotors on EBay for 55 bucks with free shipping! LOL. It's been several weeks and so far so good, no vibration. Silky smooth braking. For those considering turning the rotors, for the price you pay vs replacement, you may as well replace, especially since turning the rotors only makes them more susceptible to warpage at a faster rate.
+1 on that... and yep, always use a torque wrench. And after having work done that required wheels to be removed, go back after maybe several days or a week of driving and re-torque everything to proper spec
