ML audio in 07/08 search yea or nay?
Looking for an 07 or 08, and wondering how much better the ML system is. I realize that there are 19 vs 10 speakers. Are there tweeters on the upper doors with the ML system? I don't see them in the stock one. Seems like the ML amp fails more often than the stock. Is it worth looking for the car with the ML or could I achieve the same or better results with the stock system and upgrade an amp or the front speakers?
Go for ML
the system is designed to work in it's environment, and upgrading later may not provide the desired effect.
My 2007 L amazes me every day with the incredible sound it puts forth!
avmiii, I'm not going against the consensus here, but I would tell you to listen to both systems as you shop. If you find the ML system indispensable then go for it. If it doesn't make a difference for you, then just go for the best deal regardless.
GO ML!!! I refused to get anything without it and I'm glad I held out. It is simply the best sounding system I've ever heard. Truly breathtaking, crystal clear sound....at ANY volume.
