Maintenance plans, Oil Change mileage??
Hey,
My local dealer offered me 6 oil changes/tire rotations, 15K service and 30K service for $1,142.00.
First oil change/rotation is free.
What you guys think?
Lexus suggests 10K oil changes for 13 and up?? I'm going to change mine every 5K.
Dealer also offered me a 7yr/70K warranty for $1,957 and a 7yr/100K for $2,612.00.
I'm going to give Troy Dietrich in MA a call about pricing for extended warranties. He always treats me right. Not going to buy one right away.
Those sound like high prices, even to this Canadian.
Why? Unless you don't plan to use synthetics or you don't drive the mileage within a year. Even 10k is conservative if you're using synthetic oil.
Since 95% of that is really only oil changes, I'd skip it. The 15 and 30k services are mostly "check" this and "inspect" that. Not worth it IMO.
I have to get all my services done for warranty purposes? I got a good friend who owns a Auto repair place, he usually does all my work.I'll probably let him do it.
I need to call my Lexus Service dept? I think they said $80.00 for oil changes which isn't bad. If I do myself, I have to buy 8 quarts of synthetic plus the filter.
I didn't buy mine until the week before my 4 year warranty was up. Why give them your money any sooner than you have to?![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Here's what Lexus says to do.
15 K service
❏ Replace engine oil and oil filter; reset reminder light
❏ Rotate tires
❏ Visually inspect brake pads, calipers and rotors
❏ Check installation of driver’s floor mat
❏ Road-test vehicle
❏ Inspect the following:
___Axle shaft boots
___Ball joints and dust covers
___Body
___Brake lines and hoses
___Engine coolant (see page 69)
___Exhaust pipes and mountings
Additional Maintenance Required If You Drive Primarily Under the Following Conditions
Driving on dirt roads or dusty roads:
❏ Inspect engine air filter
❏ Tighten nuts and bolts on chassis
30K
❏ Rotate tires
❏ Measure brake rotor thickness and runout (LS 460 with F SPORT Package)
❏ Measure thickness of brake pads (LS 460 with F SPORT Package)
❏ Replace air conditioner filter
❏ Replace brake fluid
❏ Replace engine air filter
❏ Replace Smart Key battery
❏ Road-test vehicle
___Axle shaft boots
___Body
___Brake rotor thickness and runout
___Front differential oil (AWD)
___Fuel lines and connections, fuel tank band
and fuel tank vapor vent system hoses
roadfrog, Just got out of a 12 Range Rover Sport Supercharged, Land Rover said 10K for oil changes, I did mine at 7K.
I usually rotate my tires every 5K, I would rather rotate tires and get oil changed at same time or 7K for both. One less trip.
I'm going to change out my current oil at 5k miles and refill it with synthetic (I just got the car, so I don't know what type of oil is in there). Then, I'll take it to 8k miles at least and send in a sample for analysis. That'll give me a good idea where I stand for further intervals.
neilsarkar
12-15-15 09:51 AM
