Is that only for certain model years? I don't recall ever seeing that option.
Hmm, looking at the debug data that you sent me a while ago, it seems like your car doesn't support it. And neither does another LS (a 2013) that I got data from. I guess we don't support it on LS's then. It definitely shows up and works on most RX, GS, and GX models.
I'd be curious to hear whether a dealer is able to change that setting on your LS. Because from what I can see, your car is reporting that it doesn't support that setting at all. So there's either some other setting that I don't know about, or this is not configurable on your car. (talking about the seat retract here, not the steering wheel retract.)
Yes, the seat/steering wheel retract on the LS can be turned on or off by the dealer.
Interesting. Do you use Carista? Do you mind sending me a debug data report from your car? You can do that by opening the slide-out menu from the left, tapping 5 times on the "Version 2.2" label, then choosing "Collect debug data" from the secret menu that pops up... and then following the prompts to send a report. That would be much appreciated. There must be some other setting that we haven't implemented yet. Also, can you enable/disable the seat movement through your nav screen?
No, I don't. But when I asked the dealer he said they can turn it off - for a fee! I don't think I can enable/disable the seat movement through the nav screen?
but have to inform You that this is a Swiss sold model...where there are NO indictation on settings for DRL.....
Regards
Arvid
How to setup the seat/steering wheel retract? Do you need to follow certain steps to set it up or would it just be on all the time if it has been enabled?
I dunno if its the Right thread or no , but i would like to Thank Developers of Carista App , i was fed up of Seat belt noise and the DRLs i finally got rid of them ...
Thanks
Cool
Originally Posted by LS2k
On the '07 isthe seat/steering wheel retract available and can it be enabled through carista?
Seat: yes (if the car supports it). Steering wheel: no, we can't configure that currently. Hopefully a future version of Carista will be able to (for cars that support it, of course). Not sure if the '07 LS supports it in general, but I think it does.
