LS remote start install DIY
#61
All done. It took me about 45 minutes. This really was soooo simple.
I did not take any photos, because they really aren't necessary if you follow the instructions which are so very clear. I used T-Taps (red ones as the wire gauge is very thin).
Couple of things to note:
1. When all the wires are connected, remember to press the "push to start" switch three times. This will program the DBall module and the led will turn from red to green.
2. I did not connect the parking lights to the module, as apparently they will not light up if you leave your headlight switch on "auto" as I always do. I don't need my parking lights to be on while the car is running, so not an issue.
Honestly, this is as easy as it gets!
On a side note, this module is high quality and made in Canada. Very impressed. For a grand sum of about 80 dollars including the Ttaps and less than an hour of my time, I have remote start. UNBELIEVABLE.
Wish me luck, i'm going attempt install this weekend.
#62
Also,
#65
IF you are going to hook up the parking light wire, read below.
The parking lights...
the concept is that the parking lights should burn while the remote start is running. Well, because of our high tech Lexus vehicles, this doesn't work exactly how it should. I personally am just fine with the way it works. But I thought I would bring this up to you as I thought I had a bad DBALL parking light output. And come to find out, it's actually the way the Lexus wiring is done.
If your headlight switch is set in the AUTO mode, the parking lights will not burn while the remote start is running. NO LIGHTS AT ALL
If your headlight switch is in the ON mode, the parking lights will not burn while the remote start is running. HOWEVER, the headlights WILL burn.
If your headlight switch is set in the PARKING LIGHTS mode, the parking lights will not burn while the remote start is running. NO LIGHTS AT ALL
If your headlight switch is set in the OFF mode, the parking lights WILL burn while the remote start is running. THIS is how it is supposed to work.
I personally keep my headlights in the auto mode, so I get no lights while the RS is running. I'm more concerned with a cool or toasty car.
The negative polarity parking light wire in the car is the only feasible connection. Unfortunately a negative trigger to that wire, while the switch is in auto, will not trigger the parking light circuit. The only way around this would be to wire a relay to trigger positive parking lights. However, there are 9 separate positive polarity parking light wires that would need to be triggered... and all 9 would need to be diode isolated from each other.
#68
This is a lil off subject but while you guys are talking about wiring.... I have a suspension lighting kit that has a +12v lead for hooking up to a alarm, or other trigger. I'd like to wire to my dome light and I need a location. I tried at the domelight but that just triggers the lights on full time. I hv a set wired in my IS 250 and using a relay it works like a charm I found a wire in near the same location as the driver fuse box behind the dash.
Any help?
Any help?
#69
CRITICAL UPDATE!!!!!!!!!!!!!!!!!!!!!!!!
DIRECTED (DEI/Viper) has issued a recall for (SOME) RSR units and or alarm remote starts w/DBALL FOR PUSH TO START VEHICLES.... it seems that a few vehicles equipped with the DBALL have random shut down issues ... so please read the following carefully !!
FYI ANYONE WHO HAS PURCHASED A DBALL FROM ME PLEASE CONTACT ME DIRECTLY FOR ANY RECALL INFO OR FIRMWARE UPDATES!
http://www.ceoutlook.com/2014/07/24/...mote-starters/
FYI this is why you should ALWAYS use an AUTHORIZED DEI DEALER!!!!!!
#70
#71
#72
I think u misunderstood. ...push to start vehicles are affected...so we are affected..it says standard ignition key systems would not be affected what's going on is something in the CPU is causing the car to shut off that won't happen with a key because it is a mechanical device that is turned.... with push to start its a signal going to the computer what they're saying is something with the dball interrupts the signal under specific circumstances, causing the car to shut off while in motion..I put a call into the head tech to get more specific information hopefully he'll be able to get back to me next week so I can update you further this is just an email that they blast so I figured I would put the information here because a lot of guys have been adding the RSR dball systems
#73
To further elaborate if you wanna do this test yourself..start your car manually then after it's running on the vehicle system activate your remote start then step on my break if the car shuts off your vehicle is affected basically its saying that while you're driving if you accidentally bump your fob or your phone and activate the remote start then step on the brake while the car is under power or in motion the electrical system can be turned off so please test this in a park position
#74
