Abs warning lights , any help
I have Lexus 460 LS L 2007
Few months back changed the battery and every thing was ok
2 months after I had problem in the sound system ( radioand dvd ) which was on and off
one month back suddenly I had all the warning lights in the dashboard on with massage saying that that the brake system is malfoctioning and check the ABS system
I took the car to LEXUS dealer and they reprogramed the computer abd then every thing went back to normal and the problem fixed
two days after I had these warning lights again with the same massege
I do not know what to do , any help will be appreciated
99
99
99
99
If you continue to have battery problems then you should consider the doorjamb switches as a possible source.
A year ago I had problem with my battery running out of juice and I had to get my ABS system re-calibrated with the shop computer, also I had to reset the passenger side power window.
What's up with that? LS can be pain in the rear if battery is dead I guess..
bennecc
Hybrid Technology
24
07-04-24 11:10 PM
