Interior Dashboard repair
Old 07-13-14, 10:04 AM
torezcolem
torezcolem's Avatar
Default Interior Dashboard repair
Hello again, i have these few nasty spots on my dashboard, bought the car like this, any good ideas for repair or cover up?
Attached Thumbnails Interior Dashboard repair-20140706_113156.jpg   Interior Dashboard repair-20140706_113150.jpg
Old 07-13-14, 10:15 AM
CJITTY
CJITTY's Avatar
How does that even happen? If you don't have a uv blocking tint on your front windshield, you should do that. It will keep car cooler, doesn't look obvious it's tinted and cuts glare down while protecting from sun
Old 07-13-14, 10:33 AM
torezcolem
torezcolem's Avatar
Beats the hell out of me,I wondered the same thing
Tee
Tee's Avatar
Looks like the previous owner let the car bake in the sun for long periods of time with no dash protection and caused it to dry out, crack and split. Your best bet is find the best upholstery shop in town and let them repair it for you.
Old 07-14-14, 10:41 AM
RodT
RodT's Avatar
Originally Posted by tee
looks like the previous owner let the car bake in the sun for long periods of time with no dash protection and caused it to dry out, crack and split. Your best bet is find the best upholstery shop in town and let them repair it for you.
agreed!!!!!!
Old 07-15-14, 09:27 AM
brianlin87
brianlin87's Avatar
just based on the pics, i'm assuming you have an LS600 full leather dash - you could try and go to an automotive upholstery shop to see if they can fix that
Old 07-15-14, 03:41 PM
sktn77a
sktn77a's Avatar
His profile says 2007 LS460.
Old 07-15-14, 06:18 PM
Shibumi1
Shibumi1's Avatar
The leather on the 600 wont do this... the 460 will and other toyota's an lexus' 07 era have a foam laminated dash its molded to look like leather.. but its a foam composite with a vinyl like coating..that literally melts over time an long exposure to heat or direct sunlight. .the fix will be expensive. . (An effective in small non obvious locations..but that dash may require a full leather/vinyl wrap.. or a replacement. ..
In the immortal words of Kurtis Blow...."These are the Breaks!!"
Old 07-15-14, 06:23 PM
Shibumi1
Shibumi1's Avatar
If you look closely at the 2nd pic you can see the yellow foam under the vinyl coating. .
Old 07-16-14, 03:30 PM
1WILLY1
1WILLY1's Avatar
wow, ive seen a few of these 460's doing this now.
To me, it almost looks like the previous owner re-dyed the dash and now its peeling.
I would bit the bullet and have the dash removed and re-wrapped in leather or suede.
No point in fixing it if its only going to happen again.
ES250OG
09-23-18 10:55 PM
R Z
06-18-18 02:01 PM
KelRX
Automotive Care & Detailing
07-02-17 02:13 PM
iand1821
19
06-04-15 01:35 PM
BoyOhBoy
04-27-14 09:44 AM
Quick Reply: Interior Dashboard repair
