Any issues with running 235/55r18 tires?
HI everyone,
I am in need of some new rubber and can get four 235/55r18 Michelin Premier A/S tires for just under $900 installed. This seems like a good price and the tires appear to have good reviews but the sidewall is 55 rather than 50 (these tires aren't available in a size 50).
So what would be the consequences (aside from throwing off the speedo) of running these tires?
It's either the Premiers in 235/55r18 or Primacy MXM4s in 235/50r18 for about $50 less.
Thanks
Thanks
I like the Primacy MXM in the correct size(!) Also worth consideration is the Continental Extreme Contact DWS. The 55 series tires may have a slightly plusher ride at the expense of braking and cornering. I doubt you'll notice it though. Others on this forum have gone to the 55 series tire with (apparently) no fouling of the suspension or wheel arch.
HI everyone,
Thanks
Thanks
williakz: Thanks for the heads up.
I decided to go for the MXMs since they are low rolling resistance and will give me slightly better MPGs. I drive a lot so maybe over the life of the tire that will translate into slight savings.
