Run a wire from center console to underneath car?
Old 08-30-14, 09:19 AM
sparky3
sparky3's Avatar
Default Run a wire from center console to underneath car?
I'm doing the electric cutout option, and my choices are
1) Muffler shop 1 - will do everything including wiring for $450
2) Muffler shop 2 - will do just the welding for $100, no wiring.
It's a fused 12-14 gauge wire that hooks directly to accessory and a ground wire. A cinch to install myself. However, I'm not sure if there's a grommet or some other spot to run the wire through the floorboard, or if there's a hole/grommet easily accessible near the center console (with the trim piece removed of course).
Surely someone has run lights or something else underneath their car that might know this.
Yes, I've searched. Help me save $350.
Old 08-30-14, 02:49 PM
Lextrician
Lextrician's Avatar
i know the trunk has a few but if you wanna save money you do it yourself but dont be surprise if you have someone else do it and they half *** it then dont get upset. I would search around and see the closest you can get to your cutouts with the majority of the wiring being inside of the car.
Old 08-30-14, 05:07 PM
is150
is150's Avatar
I would run the wire under the dash to the power loom on the passanger side footwell to the engine compartment. From there just run the wire down and to the location you need. All I did was straightened a wire hanger and carefully pushed it threw the rubber wire loom gromet from the engine compartment to the passanger footwell. Once threw, I taped the wire to the end and pulled it threw. Only took 2 tries.
Old 08-30-14, 05:13 PM
sparky3
sparky3's Avatar
But I don't need to be near the engine compartment; rather I need to be underneath past the CATs all the way towards the rear. This is to control the exhaust cutout butterfly valve(s).
Old 08-30-14, 06:56 PM
is150
is150's Avatar
id think its still easier to run it from the engine compartment, under the car, then to the cutouts than pulling the rear seat out to access the trunk, pulling the trunk paneling out to access the gromets.
Old 08-30-14, 09:17 PM
sparky3
sparky3's Avatar
The LS430 had a grommet right under the front passenger footwell - are you sure there isn't one like this on the 460? Also, why couldn't I run it down the same area with the gearshift?
Old 08-30-14, 09:26 PM
is150
is150's Avatar
I am not sure if there is a grommet under the passanger footwell. It would make it easy if there is one. If there is an area by the gearshift, that allows access to the underbody that would work too. Let us know what you find.
Old 08-30-14, 10:07 PM
sparky3
sparky3's Avatar
Will do. Your initial idea might make the most sense actually...
Old 08-31-14, 12:37 AM
sparky3
sparky3's Avatar
Did you have to pull the battery to get it out of your way? Looks like a tight squeeze, but with some tape and a bent coathanger (like you, my old standby trick) it looks doable abeit a semi-knucklebuster.
WolfSnap
02-09-15 01:52 AM
GoodRevs
07-29-10 02:47 PM
philly777
GX - 1st Gen (2004-2009)
01-18-09 08:39 PM
FormosaSC
SC- 1st Gen (1992-2000)
01-21-08 01:14 AM
mike-ibp03
12-14-05 02:20 PM
Quick Reply: Run a wire from center console to underneath car?
