Ball joint or suspenion noise
Old 09-28-14, 08:17 AM
jarm
jarm's Avatar
Default Ball joint or suspenion noise
Every time I turn hard left or right, I hear this popping noise. Could this be ball joints, or suspension problems? Thanks
jarm
Old 09-28-14, 09:38 AM
is150
is150's Avatar
Before I say it's the control arms that need replaced can you describe when this happens? Does it only make the noise after the car hasn't been driven for a couple hours? Only at low speeds when backing up or moving forward, like pulling out of a garage or parking spot?
Reason I ask is that the front brake pads can make that same noise when the brakes are cold and you apply the brakes the first couple of times.
Old 10-01-14, 02:10 AM
LordBowral
LordBowral's Avatar
Can almost guarantee it will be the control arms How old is your car and how many miles you done ?
Old 10-06-14, 10:25 AM
jarm
jarm's Avatar
It is a 2007 with 88,000 miles.
RXGS
Suspension and Brakes
18
10-27-13 08:30 PM
giolex300
01-26-12 10:18 AM
phesa
04-14-11 05:42 AM
krappy
02-17-09 03:19 PM
Rolemodel
GS - 1st Gen (1993-1997)
17
06-14-08 11:29 PM
Quick Reply: Ball joint or suspenion noise
