2008 600h 5000 Mile Service/Oil Change
Is the going rate for an oil change and tire rotation at the dealership $180.00? What other options do you guys recommend?
Thanks
Thanks
You can do it yourself, I'm sure there is a how to in the Sticky at the top of the forum, or you can have an independent shop do it, or call around to other dealerships. I personally wouldn't take the car to a Jiffy Lube or anything like that.
Some guys have gotten lower prices from Toyota dealers, but some have had issues there.
It uses Toyota synthetic and the 460 uses over 9 quarts of it. There is talk of the oil causing hesitation issues in the 460's. I haven't heard of it in a 600. But there are other options out there.
Walmart on 280 in Chelsea. I've got them trained to do LS oil changes. Buy two jugs of Pennzoil 0W-20 ($25 each), look under the jug caps or save your receipt, register for Pennzoil/Shell FRN rewards and fill up 20 gallons of gas with a $2/gal discount. Then, buy a box of oil filter kits from Sewell at $5 each. Amazon can fix you up with the special oil filter canister wrench for around $20 as well as drain plug washers for less than $1 each. Then take oil, filter kit, wrench, and washer to Walmart. They'll change your oil for around $15. You'll have to work out the tire rotation on your own, but they're pretty reasonable and VERY well trained (at least at Chelsea). Good luck.
Yes, oil change at most Lexus dealers is around $150. When in Florida for the winter I went to a local Lexus dealer and was quoted $95. I asked what kind of oil they used and they said a Synthetic Blend. You should not use a blend. Full synthetic 0-W-20 only. As for tire rotations you can hear all kinds of reasons for it, and how often. My wife and I have owned 25 Toyota and Lexus products going back to 1978. I never rotate tires and I always put more miles on them than they are rated, before the wear bars are noticeable. Cost of rotation at 5000 mile intervals soon pays for a pair of tires. I have also had tires where they are uni-directional and the rears are larger than the front. Cannot rotate them, so I figure why rotate any tire. I know it cost a lot for an oil change, but when you purchase a luxury car you pay more for everything. Something as simple as the paper cartridge for the oil filter is quite a bit more for an LS, but is the same one used in the Toyota. If you are going to quibble over a few bucks, stay away from Luxury cars (all brands), because you will pay a premium for everything you have done to it. If I do not do the work on it, I only use a reputable Lexus dealer. No independents as they have no real responsibility to you unless you can prove negligence.
Secondly, there are independants who do NOTHING but certain Marquee brands. For example, locally here is a shop that only does BMW's. Another, nothing but VW & Porsche. Another does only Asian vehicles. Indies DO know what they're doing (at least specialty ones).....and charge about half what the dealer does.
I pay no more for anything on my Lexus than I ever paid on any of the other 20+ vehicles I've owned and in fact, CHEAPER than many (my two BMW's especially). My Ford truck was far more expensive for parts and service than my Lexus is....and certainly more frequent and often. My BMW's were and are service and parts whor*s. I bought my Lexus SPECIFICALLY because of the reliability and relatively low parts costs. The LS shares many components with other Toyota platforms, most noticeably, the Tundra.
Wow....you really need to get your facts straight. I don't even know where to start. However, for one thing, the filter used on our vehicle IS a Toyota filter. You go to the Toyota dealer and get the filter for about 6 bucks. There is no such thing as a "Lexus filter" and there is nothing "boutique" about it.
I think if you have another car you can use if this thing breaks down, you can take a little time to find parts at reasonable prices.
I'll add (as you already know) that you can get lots of original equipment right on ebay. What does a headlight cost at the dealer? I found them on ebay last night for $200 bucks. The ABS hydraulic unit is 600-700 on ebay...a couple of grand at the dealer. I found a steering rack on there for $500 bucks, at the dealer it's over 2k. I'm finding alternators and starters on there for $200...the dealer wants 1200 for the alternator.
As far as a general maintenance goes any roadside mechanic in the boons can service this car. It's a very easy car to work on that doesn't require special tools like torques bits and it shares many of the common Toyota parts that are in use today. This is primarily the reason why purchasing this car was a no-brainer especially if you do your own work.
$220 with a free tire rotation!
Thanks for the input guys. I live an hour from the dealership, so the Walmart route or my local mechanic will be the route I take for oil changes any way. Could do them myself, but I have enough to do already.
