This would be a great how to for the JDM LS460 headlights that don't have the headlight washer so the full swoosh lights up
2 Attachment(s)
Dim screen warning..... dim screen warning...lmao
I was at the bodyshop doin some wiring an took these pics. |
2 Attachment(s)
1st pic (drivers side) the nike light power lead is pink (+) white/black (-)
2nd pic (pass side) nike light power lead is yellow (+) white/black(-) They're in the same pin location on both plugs... the plugs 7 pins an using the release tab as top.. they are both located in pin2... grounds are in pin1... hope this helps |
Originally Posted by Shibumi1
(Post 8804676)
Trade secret til my build is done.. (should be done next week.. damn Fl weather)
I wish that I lived closer to Florida because I have a feeling that you'd see ALOT of our car! You do Nice work! :thumbup: By the way, does anyone know who makes the brightest LED in amber for the Nike lights? I saw that Tee and CJitty tried the 921's and said that they get too hot. I found some amber LED's that put out a little over 100 lumens (which isn't a spot light, but not bad for an accent light to accompany the amber pimps). Thanks |
1 Attachment(s)
Thanks for the kind words...an Yessir. ..Shibumi has already taken home a few trophies. ...
As for the nike lights... i did an led headlight conversion. .. it turns out an h1 bulb fits In the opening. Just silicone it in place (plus it'll keep water out) & voila SUPER BRIGHT nike lights.... i will say its easier to do with the bumper off...... Fyi i used the same trick for the reverse lights... now i can see all things behind me.... |
(Post 8847466)
As for the nike lights... i did an led headlight conversion. .. it turns out an h1 bulb fits In the opening. Just silicone it in place (plus it'll keep water out) & voila SUPER BRIGHT nike lights.... i will say its easier to do with the bumper off...... Fyi i used the same trick for the reverse lights... now i can see all things behind me.... That turned out Great! I don't usually like the body kitted LS', but yours looks Awesome! Great job! :thumbup: |
Would these bulbs work for a bright Nike light? You can't beat the price! :)
VLeds 194 Ambers............ |
Originally Posted by FreddyG
(Post 8848332)
(Post 8848549)
They'll fit for sure..but i dunno how bright they are.... the led kit i used had a slim ballast like an hid...$129 a pr shipped 1yr warranty (an I've only seen them in white =6k)
If they fit, then I'm only out a buck for the pair and since I was going to order some LED's anyway, I might as well see how bright they are. |
(Post 8848710)
Thanks Shibumi! They look Awesome, but that's a bit too rich for my blood (I'm Cheap :D).
If they fit, then I'm only out a buck for the pair and since I was going to order some LED's anyway, I might as well see how bright they are. Let us know how those bulbs work out.. an post some pics of the color I'd like to see that... |
(Post 8849092)
Gotcha. .. but @ $1 i wouldn't expect them to last long.....if they are what u end up going with I'd order more than 1pr as they'll undoubtedly burn out.... in my cars i always go with reliability... looks kinda of broke to run around town in an 80k car with lights out..... everytime i see a merc or bmw with lights out i laugh to myself..
Let us know how those bulbs work out.. an post some pics of the color I'd like to see that... I've found some bulbs that appear to be better that I'm going to try out. I'm still sticking to the amber color because I think that they'll look better with the amber pimps and kind of break up all of the bright white light. I will post pictures after I put them in though. Thanks again for your advice and help! :) |
2 Attachment(s)
Found these pics today...just thought I'd share. .. (11am with no filters)
(Post 8855938)
these pictures... :D
love that bumper and kit! |
I install a bad led and It over heated. Do you know where is the nike light fuse is at.
