Ride quality
The toe-in numbers for the back or front wheels are measured as follows:
* measure the distance between the centres of the rear of the left and right wheels - this is B
* measure the distance between the centres of the front of the front and and right wheels - this is A
* B-A is the toe-in distance.
* The toe-in angle meanwhile is the sum of the left and right toe angles.
It seems Toyota don't specify that you measure the individual toe angles separately.
Therefore:
* TOTAL front toe should be -0°10' to +0°10'
* TOTAL rear toe should be 0°5' to +0°25'
Common sense would suggest that you want individual toe measurements to be half of that,, i.e. front -0°5' to +0°5', and rear 0°2.5' to 0°12.5'
Keep in mind that camber cannot be adjusted independently from toe on our cars. Camber and toe are linked so just because the camber is off it doesn't indicate anything is wrong until toe is adjusted and it will usually come back into specification.
It's good that you found the problem with the original alignment.
Number 8 is the process of actually checking/measuring the suspension parts (suspension and control arms), to check if they need replacement.
Therefore:
Therefore:
The rear camber/caster is not adjustable - for toe-in you turn the adjust cams.
You can adjust the FRONT camber and FRONT caster by turning the suspension cross member (adjusts caster and camber, but one side caster more than the other), moving front to rear (adjusts caster), or left to right (adjusts camber). On the AWD cars there are separate left front, left right, rear right and rear left cams for adjusting this. For toe-in you adjust the rack end lengths .
http://workshop-manuals.com/lexus/ls...ent/page_2034/
For the RWD:
http://workshop-manuals.com/lexus/ls...ent/page_1978/
For the AWD:
For the RWD:
For the RWD:
It appears that the AWD is done with eccentric cams and the RWD is done with shifting the cross member plate and then locking it up.
The alignment on these cars is a lot more sophisticated then I imagined and will require a trained technician and a lot of time.
My 2010 460L picks up every little bump and crack in the road and, it also floats (like has been described). I'm not use to that because my 2006 430 did not and had a much smoother ride.. The 460L has air suspension and AWD. The ride bothers me every time I drive.
zhaoyi2333
03-15-19 06:13 PM
brianlin87
06-05-06 08:04 PM
