is this acceptable?
Old 01-03-15, 09:17 PM
Vi-Tuyen
Vi-Tuyen's Avatar
Default is this acceptable?
My Ls got hit and run, the car got hit on the driver quarter panel. brought my car to Sewell Lexus of Fort worth for the repair. After the repair done, the quarter panel look good but the rear bumper cover is not so good. the corner piece where the bumper meet the taillight keep sticking out. I pushed it in and it looks ok but after awhile it pop back out. I notice the paint has small crack. I called the repair adviser and brought the car back for the fix. After over a week, I got the car back. It looks ok when I got the car back, but now it pop back out and it is worse. what should I do now?
This is the first accident repair for this car.
driver side
passenger side
Old 01-03-15, 09:53 PM
CJITTY
CJITTY's Avatar
Tell em nice try and do it again. Don't settle for mediocre repairs...this isn't some $600 car you are trying to sell on Craigslist.. Make them do it right
Old 01-03-15, 11:20 PM
lalaura
lalaura's Avatar
No! I backed into a neighbors truck he'd parked in my driveway & had body work & new rear bumper and that same panel replaced mine looks great - yours looks lime mine did after the accident. I had mine repaired locally w/ a shop noted for outstanding work. I wonder if they cut corners on yours! My bill was about $3300 as I recall
Old 01-04-15, 12:12 AM
Soldier76
Soldier76's Avatar
Nope have them fix it to Lexus quality standards, and let them know this is a super luxury car, not some pinto.
Old 01-04-15, 12:46 AM
Shibumi1
Shibumi1's Avatar
They only replaced the bumper they need to replace the "J" shaped retaining clips on either side.... i know as i just did this.. (bumper was put on an off 20x) also make sure they use and tighten the 10mm screws. Clips cost about 100 ea...
Attached Thumbnails is this acceptable?-20140318_181259-1.jpg   is this acceptable?-20140318_181259-2.jpg
Old 01-04-15, 06:20 AM
Nospinzone
Nospinzone's Avatar
Definitely not acceptable.
Old 01-04-15, 07:05 AM
roadfrog
roadfrog's Avatar
That looks horrendous. Take it back to them.
Old 01-04-15, 08:00 AM
R Z
R Z's Avatar
Totally agree with the others. Until you are satisfied, keep going back. They'll make it right.
Old 01-04-15, 12:06 PM
Vi-Tuyen
Vi-Tuyen's Avatar
Thanks all. I'll call them tomorrow.
Old 01-04-15, 12:59 PM
Devh
Devh's Avatar
Just for future reference you should always request someone come out with you and explain the work that has been done after the car is fixed. They will be embarrassed when they see the quality of the work in front of you. Some may even pass it off as the best that they can do and you can tell them if they could have it in writing so you can get a second opinion somewhere else.
I'm not supper critical but that work is certainly not acceptable.
Old 01-04-15, 01:32 PM
dlbuckls10
dlbuckls10's Avatar
Unhappy
No way! This is unacceptable and noticeable. Keep going back until it's done right.
Old 01-04-15, 03:43 PM
sktn77a
sktn77a's Avatar
Broken clip or the clip wasn't attached properly. Simple fix. Take it back and tell them that!
Old 01-04-15, 05:10 PM
peteybabes
peteybabes's Avatar
that would stick out like a sore thumb if i did a pre-purchase inspection! sorry for the trouble you're being put through...
Old 01-04-15, 09:54 PM
CBS70
CBS70's Avatar
+1. It's the clips that fail over time and if damaged. I just replaced the J clips and back to perfect after looking just like yours. Good Luck!
Old 01-05-15, 10:45 AM
Vi-Tuyen
Vi-Tuyen's Avatar
I just took a peak at the "J" retainer, look like they did not replace it but use epoxy to glue it back. sucks
dunbar43
07-06-10 12:51 PM
datboililp
06-13-09 06:53 AM
llamaboiz
07-31-08 01:04 AM
unscathed
SC- 1st Gen (1992-2000)
04-17-07 01:37 PM
stefnee
NELOC
04-05-07 08:14 PM
Quick Reply: is this acceptable?
