LED front turn signal bulbs DIY with pics
Old 01-10-15, 12:15 PM
CJITTY
CJITTY's Avatar
OK man.. You are pretty thorough so you sold me! I've even considered putting stock tails back on with a pair of these on each side..two 921 bulbs with this set up probably look really good..but I live my avest tails at night
Old 01-11-15, 11:01 AM
ShahG
ShahG's Avatar
Will these fit the tails?
Old 01-11-15, 03:35 PM
CJITTY
CJITTY's Avatar
As I mentioned above, probably so but the bulbs are 921 not 7440 and each lens has two bulbs for turn signals. You would need 3 orders. 1 set 7440 amber for front signals and 2 sets of 921 in white/clear for rear signals
Old 01-11-15, 06:16 PM
ShahG
ShahG's Avatar
Thanks for the Info. I tried Carid's Lumen series Plasma Bulbs, with seperate resistors, with no luck. Hopefully these will do the trick.
Old 03-07-15, 02:24 PM
PrinceAkim
PrinceAkim's Avatar
Just finished my install, thanks for the write up!
Old 03-07-15, 02:57 PM
roadfrog
roadfrog's Avatar
Good to hear.
FWIW, mine are still working great and no issues at all.
Old 03-07-15, 07:23 PM
CJITTY
CJITTY's Avatar
Cool man..looking forward to seeing them
Old 03-08-15, 12:23 AM
KING
KING's Avatar
Been looking to adding LED's, but just worried they would'nt fit or they would need a resistor. Thanks for the suggestion. They look good!
Do you get 2 LED's for $36.79?
I ask because in the details it says "1 x 5W CREE LED".
Old 03-09-15, 07:29 AM
roadfrog
roadfrog's Avatar
Yes, you get two (set), as per the item description:
"This page features one set Error Free No Resistor Required CREE High Power 7440 LED Bulbs w/ Plug-N-Play cancellers, exclusively designed for front turn signal lights or rear turn signal lights ONLY ."
Old 03-11-15, 11:43 AM
justjosh
justjosh's Avatar
Will these bulbs work in a LS600hL? Also can you just swap in a LED flasher in the LS's to eliminate the hyper blinking? That's the route I went in my ISF and I have a lot of extra LED bulbs I could use for my LSh and just get a LED flasher.
Old 03-11-15, 08:21 PM
macjac69
macjac69's Avatar
Installed mine today took a comparison video, trying to upload it.
Old 03-12-15, 06:11 PM
CJITTY
CJITTY's Avatar
On Youtube?
Old 03-13-15, 08:25 AM
macjac69
macjac69's Avatar
Yes, I uploaded it to my acct just don't know how to attach here...
Old 03-13-15, 01:01 PM
Tee
Tee's Avatar
I received my LED's today and will install tomorrow, pretty straight forward like the LED DRL install.
Old 03-13-15, 05:47 PM
macjac69
macjac69's Avatar
Take care when installing the harness and resistor into the housing itself as I just kinda stuffed it in wrong as it were and I got an ASF display window when embarking on my roadtrip.... and had to correct that before I left. Three days later they haven't given me any problem.
Quick Reply: LED front turn signal bulbs DIY with pics
